Engine stumble any help?
Old Feb 4, 2003 | 06:47 PM
BLU98's Avatar
Account Suspended For Flagrant Cross-Posting
Unhappy Engine stumble any help?
I just installed Denso plugs gapped at 50, new Accel wires and Accel coil packs along with a Airforce One Cold air kit over the weekend. Drove to and from work on Monday and had no problems at all. Now today I drive to work and when I was stopped a lights the truck would like stumble and run rough for a few seconds and stop after a couple of time! So I drove around for down the highway while using my Auto-X-Ray scanner plugged in for capture mod. When I came to a light and stopped the truck did stumble again. I went home and read the scanner and no codes or real time problems. It doesn't do it all the time it's intermintent! It did not do this till I installed the above products! Any help or info that will point me in the right direction will be greatfully appreciated!
Old Feb 4, 2003 | 06:54 PM
BLU98's Avatar
It's a 98 F150 4.6 auto wit 33000 miles on it daily driven. Mods so far are: Accel wires, Accel coil packs, Denso plugs gapped at 50, Air force 1 intake all which were installed this weekend. And I also have the Micro Tunner and a Transgo shift Kit. I also noticed that when I have the above problem I can hear like a ticking sound under the hood and in the dash I believe! I checked for cross fire and arching and can't find anything!
Old Feb 4, 2003 | 07:27 PM
Unlawful's Avatar
Registered User
It could be one of your plugs may have backed off. I'd check it anyway, as we know Ford does have a plug blowout problem
Old Feb 5, 2003 | 04:42 PM
BLU98's Avatar
Found it! Spark plug wire on number 4 was not on all the way!
Old Feb 6, 2003 | 01:35 AM
offroadmaniac's Avatar
Always seems to be something with that sparkplug #4.
