Funny smell
Old Jan 29, 2003 | 04:49 AM
spray004's Avatar
Question Funny smell
I have a 98 F150 , with a 5.4L and E4OD. I've noticed a funny smell lately after I get out of my truck. I dont know if anyone has ever smelt what a gas powered remote control car exhaust smells like, but its exactly the same smell thats coming from underneath my truck. I dont know if it's my transmission or engine or what? Could it be burnt trans fluid?
Old Jan 29, 2003 | 05:04 AM
mf150's Avatar
Hey! welcome. You should check your exhaust lines for deceased rodents. That might cause the smell you described. J/K
Actually, I don't have a clue what that smell might be. Just hang tight there are many brilliant people on this sight, and I'm sure they will give it their best shot!
Old Jan 29, 2003 | 05:45 AM
spray004's Avatar
lol, its not that bad of a smell. the only way i can describe the smell is that its a sweet smelling odor but kinda burnt. i just wanna know what it is before i get stranded.
Old Jan 29, 2003 | 05:58 AM
mville656's Avatar
It could be antifreeze leaking onto the exhaust. I think it has a habit of leaking on the right side towards the rear of the engine.
Good luck,
Mike
Old Jan 29, 2003 | 08:32 AM
racer47's Avatar
When I seen this , I had a funny thought come to mind. Nothing against you Spray, BUT, does anyone else find it funny that someone using the name Spray, would be complaining about a smell?
Sorry Spray, just couldn't resist.
Old Jan 29, 2003 | 08:44 AM
ViperGrendal's Avatar
I had an antifreeze leak on my expi that was dripping onto the exhaust that smelled just like you described. My leak was in the lines leading to the rear heater/ac unit that ran through on the passenger side. You don't have that on the f-150 but there are other hoses that run through there. You can look around on the passenger side and try looking for a yellowish liquid pooling or dripping anywhere. On mine you couldn't see where it was coming from exactly but you could see where it sprayed and dripped when the engine got hot.
You can also do a search on antifreeze/coolant leaks on the forums here and there should be more info that might more closely aply to your situation.
Keep an eye on all your fluid levels in the mean time. Hope this helps.
Old Jan 29, 2003 | 01:25 PM
hcmq's Avatar
check the hose connection that is famous for leaking on the back pass side coil on the 5.4's. it could be dripping ever so slightly down onto the exhaust manifold.
or it could be the head gasket. mine is seapping just enough oil to get on the manifold so my truck stinks. but none reaches the ground and the level doesn't drop between oil changes.
Old Jan 29, 2003 | 01:40 PM
Green_98's Avatar
bad cats smell like rotten eggs ive heard
Old Jan 29, 2003 | 02:54 PM
spray004's Avatar
I havent noticed any coolant leaks on the ground here lately. I did notice the other day when I pulled my oil cap off, that it was covered in white goo because water had gotten around it. I checked my oil and it is black, so I'm guessing a little moisture got underneath the cap.
Old Jan 30, 2003 | 12:21 AM
mville656's Avatar
I don't think the antifreeze makes it to the ground. It gets burned off first.
Mike
Old Jan 30, 2003 | 02:54 AM
spray004's Avatar
but what about when its not running? it could still leak then
Old Jan 30, 2003 | 04:34 AM
mville656's Avatar
There is no pressure on the system when the engine is not running. It starts losing pressure as soon as you shut it off and is all the way bled down when the engine is cool.
Check out that hose. I bet it is your problem.
Mike
Old Jan 30, 2003 | 05:42 AM
toomanybike's Avatar
you know you really dont need to look into this any farther the truck is bunk and you need to sell it. take the first offer you get and run with a smile. ill give you 2000. sounds good. ok
Old Jan 30, 2003 | 05:44 AM
one more interesting thing spray. did you notice your last two postings were exaclty 12 hours apart. what in the heck are the odds of that. call me when you want to make thi deal
Old Jan 30, 2003 | 12:06 PM
Green_98's Avatar
the white stuff in your oil cap is normal its just condensation from the crank case trying to escape. Chekc your heater and raidiator hoses for leaks on the manifolds and other places that get hot and could cause this smell.
