Help, My 98F150 dies out
Old Jan 2, 2003 | 11:09 PM
ElBlackangel's Avatar
Question Help, My 98F150 dies out
Have Posted message on General Help: my truck, a 98 F150 with a 4.6 keeps dying out on me. It starts ok, there is no "Check Engine" and once I get it on a a strech of road it runs great but watch out at stop lights an stop signs, an can you imagine yields an stop & go traffic, You have to have one foot on gas an the other on brake. Can Anyone give me Ideas to checkout with out r & R everthung under the hood. I have replaced the TPS switch on Mr. AUTO parts Advise, no help, also had battery check out it was good, Have been told to have fuel Pressure checked out, will do, but I will always take any advice. I Thank anyone who has any ideas. Please Post a Reply ASAp.
Old Jan 2, 2003 | 11:40 PM
B-Man's Avatar
Cool
Having to drive with both feet to keep it running ?
Could be a vacuum leak. Check all of the major vacuum lines under the hood. That's the 1st place I'd look, with the info you've given...
Good luck !!
Old Jan 3, 2003 | 12:33 PM
01 XLT Sport's Avatar
You don't say how many miles are on your truck. Since it is a 98 I am figuring its somewhere around 40,000 - 60,000 or more. Have you ever had the fuel filter changed? If not you might want to do that. It may or may not help but it would be about time to change it.
Old Jan 3, 2003 | 01:08 PM
gmt's Avatar
gmt
Check the EGR valve
Had one stick on my outlaws Town Car... drove almost 400 miles through KY using both feet. Just an idea.
Greg
Old Jan 3, 2003 | 01:11 PM
KT's Avatar
KT
If the 98 mod has one have the IAC valve checked, I have heard of some people having luck by just tapping on it with the plastic handle of a screwdriver or removeing it and cleaning it with throttle body cleaner but if it is determined to be bad it would probably be best to replace it.
Old Jan 3, 2003 | 10:35 PM
Thumbs up IT HAS BEEN HEALED
I thank you all for your advice, the last posted message turned out to be correct the Idle Air Control Valve(IAC) was stuck with a lot of carbon buildup, also asked Shop Foreman at local Dealership he also said either Tap it to lossen it up, or if Carbon Buildup is excessive taopping won't work, needs cleaning, with Carb. Cleaner. This is a tempoary solution replacement is the long term solution. Unfortuantly funds short at this time so I'll wait until next Pay day. Well thanks to all and Hope it helps someone out there either now or in the future.
Old Jan 4, 2003 | 12:50 AM
HarleyD1's Avatar
Hey KT, good call.
Where is this valve located, I have a 98 too.
Old Jan 4, 2003 | 02:07 AM
mjhpadi's Avatar
I had the same problem with my 98 and it ended up being condensation from the A/C dripping onto the oxygen sensor and shorting it out. Glad you found the problem.
