PS leaking
Old Dec 21, 2002 | 05:26 PM
Erica's Avatar
PS leaking
I noticed a few months ago that my PS fluid was leaking. I took the pressure line that was leaking off and it was just a bit loose I figured that could be the problem. I used teflon tape and tightened it back up. Went a few weeks and didn't notice anything. Well I went to change the oil today and that same darn line is leaking all over again. It's leaking right at the pump where the fitting is. I am guessing that it's comming from the pressure fitting. If u grab the line and wiggle it u can see the metal part that goes through the fitting jiggle and move. So that's what I think is my problem. Has anyone experienced this before? Also man they put that thing is such a tight spot any good ways to loosen and tighten the line? Crows feet or anything special to make it easier? I had a hell of a time doing it the last time and I am dreading it this time too. Well any info would be great.
Lorenzo
