1986 Ford F150 Left side not firing!!! Help Plz!!
Old Dec 19, 2002 | 06:52 PM
opee316's Avatar
To anyone out there, can you please help me. I have 1986 Ford F150 and the left side is not firing. (The passenger side of the motor.) Can someone please help me in troubleshooting this problem. Also please e-mail me at this address: cajun_rue@yahoo.com
Phil
Old Dec 19, 2002 | 07:37 PM
Home skillet's Avatar
Need more info.
Is it fuel injected?
How do you know it's not firing?
Old Dec 19, 2002 | 09:33 PM
GearHead_1's Avatar
I saw something similar to this a LONG time ago. I don't remember all the details but it was on an injected 302. I believe that the right and left banks had seperate grounds for the injectors and the ground on one side was bad. I might be leading you down the wrong road this was quite a while ago.
Old Dec 20, 2002 | 12:52 AM
opee316's Avatar
It's fuel injected and we tested it by taken the spark-plug wires off one by one and touched it to the dis. cap. The right is firing just fine. But when you check plugs 1-4 it's not firing like the right side.
F-150
1986
Fuel Injected
5.0 L 302
Thanks for the info so Far!!!!
Old Dec 20, 2002 | 08:01 AM
KT's Avatar
KT
I have limited knowledge of this engine but i believe it would be throttle body injection? Does it have a coil for each bank or one runs all? If it has one for each bank then i would suspect the coil for that bank.
Also not being rude but for future referance the passenger side is normally refered to as the right side.
