SparkPlugs and Wires
Old Aug 8, 2002 | 02:33 PM
InfamousFord's Avatar
I have a 99' F-150 4.2 and was wondering what type of sparkplugs and wires I should put on it for maximum performance. I have had it since early 1999 and have never changed the plugs or wires. Does anyone have any suggestions on what would be the best?
Appreciate any response.
Old Aug 8, 2002 | 03:29 PM
Emissions's Avatar
Id take a look at some Bosch platinums. Stay away from splitfires they have a tendancy to foul up. Bosch has good wires too.
Old Aug 8, 2002 | 04:00 PM
WrongdayJ's Avatar
It's tough to beat the OE Motorcraft wires. They are correct for your truck in many ways other than just the custom fit lengths (which is nice). I recommend sticking with them.
As for plugs. . .well, the OE Motorcraft plugs are a good plug and are also tough to beat. Denso, though, would be my recommendation for a performance step up. . .although unless you are really pushing the performance envelope, the Motorcraft plugs are more than enough.
Stay as far away from Bosch platinum and splitfire as you can.
Hope this info helps,
---J
Old Aug 8, 2002 | 04:46 PM
scottie's Avatar
I AM USING PLATINUM +4 RIGHT NOW AND THE TRUCK SEEMS A LITTLE SLUGGISH THAN BEFORE. ANYONE ELSE USING THESE PLUGS?
Old Aug 8, 2002 | 05:28 PM
Talleywacker's Avatar
Suspended For Violation of Vendor Rules
I agree with wrongdayJ on this one...
If you want MAXIMUM performance from a plug... you will want Motorcraft COPPER plugs. however they will need to be replaced every 25-30k for optimum performance. I recommend AWSF 32C.
The denso's are a awesome plug but you can get a whole set of motorcraft plugs CHEAPER than 1 denso plug. They are a great plug that will last a very long time tho.
Old Aug 8, 2002 | 09:28 PM
02RegularCab4x4's Avatar
I agree with what most of the above said. Bosh suck! Motorcraft or Autolite platinum.
Old Aug 26, 2002 | 04:15 PM
fdpike's Avatar
Is there a life span to plug wires. I always thought if they were not hard or frayed then they should be ok.
Old Aug 26, 2002 | 04:38 PM
WrongdayJ's Avatar
Very good question.
Plug wires are one of those items that are replaced on an 'as-needed' basis. You should regularly check them for cracks and torn boots, and for resistance. Remove one plug wire and attach one lead of a voltmeter to one terminal of the plug wire, and the other lead to the other terminal. Record the resistance (in Ohms) and the plug wire number (of the cylinder it goes to) on a piece of paper. Do this for all your wires. Then see if any of the numbers are significantly higher or lower than the others. They should all be about the same. . .if not, then it's time to replace them.
Hope this info answered your question.
---J
Old Aug 26, 2002 | 05:31 PM
Peacemaker's Avatar
Does Motorcraft or Autolite make ouble platinum sparkplugs? And if so, how long do they last?
Old Aug 27, 2002 | 08:10 AM
fdpike's Avatar
Thumbs up
Yes it did wrongdayJ, thank you.
Old Aug 27, 2002 | 02:10 PM
crashz's Avatar
Does anyone know of any coil pack upgrades as well? Is there anything on the market that will add to the performance, mileage and cure our "rough" idle? I 've seen adds for the Jacobs systems, but it doesn't look like a multiple coilpack system.
Thanks!
Old Aug 27, 2002 | 03:40 PM
gaudenti's Avatar
Any comments on Magnecor wires?
http://www.magnecor.com/
Old Aug 29, 2002 | 11:11 AM
BroncoAZ's Avatar
I've had great luck in my 87 Bronco (302 motor) with the NGK v groove plugs. They seem to last very well. Has anybody tried the NGK's in the 4.2? I'm at 24K miles, so it's time to do the plugs. Anybody know how much the motorsport wires cost?
Thanks,
Mitch
Old Aug 29, 2002 | 01:44 PM
fdpike's Avatar
Do the plugs in the 4.2 come out easly. Are they hard to get to. About how much time should i give myself for the change.
Old Aug 29, 2002 | 05:24 PM
I bet any newbie that can turn a wrench can do this in one hour or less... I do it in about 20 minutes.
