Two Questions HELP
Hey People...
I got a pair of questions for all of you.. 1st one is, I just installed an AIRAID intake and it works fine. The only problem is the sensor that goes into the tube is too small. SO when I put it in it just falls out.. Any sugestions ? Second ? My power window switch is giving me some trouble. I realy got to push down on it real hard for the window to got up or down ? Loose wire ?? I dont know.. Any suggestions on this will help out... Thanks Everyone.
On the intake you can use a rubber tube which you slide over the sensor and then over the part on your intake tubing to hold the 2 together. As long as the 2 are touching and are covered by the rubber tube it will be fine. I have Volant, and I know what your talking about because they give you a small rubber tube about 5" long to put over the sensor, and then over the connector on the intake tubing. As long as your check engine light isn't on your alright. Sorry can't help ya with the power windows because in my truck my power windows is my arm.
