Service advance trac
Old Oct 6, 2025 | 02:31 PM
grizzeyes's Avatar
Light came on at 217,000 miles.im low income, can someone tell me what the cost might be? I can’t take it in until end of month. Diagnosis 100.00 then I guess I’ll need to see what they find! Truck runs fine .
Old Oct 6, 2025 | 06:39 PM
AI Overview
A "Service AdvanceTrac" warning on an F-150 indicates a fault in the vehicle's stability control system, commonly caused by issues with wheel speed sensors, ABS module, or steering angle sensor. You can try a simple restart, but if the light returns, you need to have it diagnosed with an OBD-II scanner that reads ABS codes.
Troubleshooting Steps
  • Use an OBD-II Scanner:
    • If the warning light comes back on after a restart, you'll need to get the vehicle scanned for trouble codes. A standard check engine scanner might not read the codes for the AdvanceTrac system, so a more advanced scanner or a professional diagnostic tool is often necessary.
  • Inspect Sensors and Wiring:
    • The most common culprits for this warning are the wheel speed sensors and the steering angle sensor. Also, check wiring harnesses for damage or corrosion, as a faulty connection can trigger the warning.
  1. Check for a Temporary Glitch:
    • Turn the vehicle off completely, wait a few minutes, and then restart the engine. This can sometimes clear a temporary system error.
  2. Check for Obvious Damage:
    • Visually inspect your tires, wheels, and surrounding areas for any obvious damage or loose connections, such as dirt or corrosion on wheel speed sensors or wiring.
Common Causes
  • Wheel Speed Sensors:
    These sensors are crucial for the system to know how fast each wheel is turning. Dirt, damage, or a faulty sensor can cause the warning.
  • ABS Module:
    A problem with the Anti-lock Brake System (ABS) module, which is integrated with the AdvanceTrac system, can also trigger the warning.
  • Steering Angle Sensor:
    A failing steering angle sensor, sometimes caused by a broken clock spring (a coil of wires in the steering column), can also trigger the warning.
  • Low Battery Voltage:
    In some cases, a weak or failing battery can cause various electronic systems, including AdvanceTrac, to malfunction.
If the Warning Persists
  • If simple troubleshooting steps don't resolve the issue, it's best to have your F-150 diagnosed by a qualified technician. They can pinpoint the exact faulty component using specialized diagnostic tools.
Old Oct 9, 2025 | 12:19 AM
grizzeyes's Avatar
Originally Posted by glc
AI Overview
Common Causes
  • ABS Module:
. HEY, thanks very much. I hate saying it but I be been trying to sell my truck for 2 yrs. I don’t want to drive a ford and was stupid to buy it! I was the dumbest guy around to buy it it looked so good!
I don’t even want the truck but maybe I’ll learn my lesson some day
Old Oct 14, 2025 | 03:03 PM
offlineme's Avatar
Go to the garage "just to see" → they will do a paid diagnosis and push for quick repairs. Replacing parts at random (it may be useless)
Old Oct 21, 2025 | 12:42 AM
grizzeyes's Avatar
Thanks for the common sense kindness. I’ll be out 100 bucks. Plus even more but I’ll see how they can’t work with me a 996.00 income. Not much room to spare! I’ve lowered the price to 9k nobody wants it!
Old Oct 21, 2025 | 07:19 AM
Veteran: Army
seems even you don’t want it
