Diagnostic help
Old Nov 6, 2021 | 11:05 AM
Stizuner's Avatar
Diagnostic help
Hey everyone, first post.
yesterday while towing across Nevada, our 2011 F-150 eco had a loud whine noise appear while passing a vehicle. Immediately after passing I lost all power so moved off the road. Engine light was flashing and I turned off the truck. Plugged in scanner to obd2 and ran codes. I had a ton of codes like cycliner misfire etc.
truck wouldn’t start and someone I was with recommended clearing the codes so we could see what was actually happening rather than the result of losing power. We reset the computer, the Truck started only one time and ran pretty rough for about 2 minutes, whine was still there and rough idle.
i assume it’s the turbo, but would love to hear some other possibilities. With turbos being close to 1k, I did find a motor with 30k on it for a great price so think unless it’s something minor I’ll just replace the motor. But hey I would love to hear what the experts think could be wrong.
I’ll have dealer run diagnostics on Monday.
Old Nov 6, 2021 | 11:09 AM
Roadie's Avatar
List the codes if you saved them.
Old Nov 6, 2021 | 11:18 AM
Stizuner's Avatar
these are the codes after the original event. Car Scanner ELM OBD2
DTC report
Selected brand: Chevrolet
============1==============
P054A
Raw code: 054A
ECU: Engine control unit[Archive (inactive)]
Status: Permanent
OBDII: Camshaft position (CMP) sensor B, cold start - timing over-advanced
============2==============
P054C
Raw code: 054C
Status: Permanent
============3==============
P0217(00)
Raw code: 021700
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
OBDII: Engine over temperature condition
============4==============
P0217(00)
Raw code: 021700
============5==============
P0012
Raw code: 0012
Status: Pending
OBDII: Camshaft position (CMP), intake/left/front, bank 1 - timing over-retarded
============6==============
P0022
Raw code: 0022
Status: Pending
OBDII: Camshaft position (CMP), intake/left/front, bank 2 - timing over-retarded
============7==============
P0151
Raw code: 0151
Status: Pending
OBDII: Heated oxygen sensor (HO2S) 1, bank 2 - low voltage
============8==============
P0300
Raw code: 0300
Status: Pending
OBDII: Random/multiple cylinder(s) - misfire detected
============9==============
P0304
Raw code: 0304
Status: Pending
OBDII: Cylinder 4 - misfire detected
============10==============
P0305
Raw code: 0305
Status: Pending
OBDII: Cylinder 5 - misfire detected
============11==============
P0306
Raw code: 0306
Status: Pending
OBDII: Cylinder 6 - misfire detected
============12==============
P054A
Raw code: 054A
Status: Permanent
============13==============
P054C
Raw code: 054C
Status: Permanent
============14==============
P0012(00)
Raw code: 001200
Status: Pending, Test failed since last DTC clear, Test not completed during this operation cycle
============15==============
P0022(00)
Raw code: 002200
============16==============
P0151(00)
Raw code: 015100
============17==============
P0300(00)
Raw code: 030000
============18==============
P0304(00)
Raw code: 030400
============19==============
P0305(00)
Raw code: 030500
============20==============
P0306(00)
Raw code: 030600
============21==============
P0012(00)
Raw code: 001200
============22==============
P0022(00)
Raw code: 002200
============23==============
P0151(00)
Raw code: 015100
============24==============
P0300(00)
Raw code: 030000
============25==============
P0304(00)
Raw code: 030400
============26==============
P0305(00)
Raw code: 030500
============27==============
P0306(00)
Raw code: 030600
============28==============
P0012
Raw code: 0012
Status: Pending
============29==============
P0022
Raw code: 0022
Status: Pending
============30==============
P0151
Raw code: 0151
Status: Pending
============31==============
P0300
Raw code: 0300
Status: Pending
============32==============
P0304
Raw code: 0304
Status: Pending
============33==============
P0305
Raw code: 0305
Status: Pending
============34==============
P0306
Raw code: 0306
Status: Pending
============35==============
P054A
Raw code: 054A
Status: Permanent
============36==============
P054C
Raw code: 054C
Status: Permanent
============37==============
P0012(00)
Raw code: 001200
============38==============
P0022(00)
Raw code: 002200
============39==============
P0151(00)
Raw code: 015100
============40==============
P0217(00)
Raw code: 021700
============41==============
P0300(00)
Raw code: 030000
============42==============
P0304(00)
Raw code: 030400
============43==============
P0305(00)
Raw code: 030500
============44==============
P0306(00)
Raw code: 030600
============45==============
P0012(00)
Raw code: 001200
============46==============
P0022(00)
Raw code: 002200
============47==============
P0151(00)
Raw code: 015100
============48==============
P0217(00)
Raw code: 021700
============49==============
P0300(00)
Raw code: 030000
============50==============
P0304(00)
Raw code: 030400
============51==============
P0305(00)
Raw code: 030500
============52==============
P0306(00)
Raw code: 030600
============53==============
P054A
Raw code: 054A
Status: Permanent
============54==============
P054C
Raw code: 054C
Status: Permanent
============55==============
P0217(00)
Raw code: 021700
============56==============
P0217(00)
Raw code: 021700
============57==============
P2610
Raw code: 2610
Status: Pending
OBDII: Engine control module (ECM) - internal engine off timer performance
============58==============
P054A
Raw code: 054A
Status: Permanent
============59==============
P054C
Raw code: 054C
Status: Permanent
============60==============
P0217(00)
Raw code: 021700
Status: Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
============61==============
P2610(00)
Raw code: 261000
============62==============
P0217(00)
Raw code: 021700
============63==============
P2610(00)
Raw code: 261000
Old Nov 6, 2021 | 01:08 PM
To make it easier to follow:
P054A
P054C
P0217
P0012
P0022
P0151
P0300
P0304
P0305
P0306
Correct?
Old Nov 6, 2021 | 03:39 PM
Roadie's Avatar
I'm no expert for sure but I think I would verify all the ground cables are making good contact. And battery cables of course.
Old Nov 12, 2021 | 05:53 PM
FX-4 Man's Avatar
I think I found your problem from your first code scan list
...these are the codes after the original event. Car Scanner ELM OBD2
DTC report
Your truck is a Sh1trolet
[takes bow] thank you, thank you, don't forget to tip your waitress
