First Ford - did I make a mistake?
So I've purchased my first Ford. 2015 F150 SuperCrew 4x4 Platinum 3.6 EB. I love the truck but hate the engine. Doesn't feel like I have enough power to outrun a fire truck. I previously had a Tundra 5.7L that would throw you back when on the pedal. Can you guys please tell me some things I can do to improve the lag? Would dual exhaust sound silly on the 3.5? Again this is my first Ford so basically just looking for advice or suggestions. Thanks
Dual exhaust does nothing for power. Look at getting a tuner. Single best power producer you can get.
Are you turning off the traction control before launching from a stop? Or is this while you are already at speed?
Not sure, but my Eco pushes me back in the seat and hauls effing ass either way... And it's stone bone stock.. Tows my #5000 like it's not even there.. Well, at least compared to my old 97 F150 with the 5.4 in it.. ;) I have found that it launches much better if you just 'roll' into the throttle from a complete stop instead of just mashing it to the floor the instant you want to go. I also find it does better rolling into it while running at speed too.. If I just mash it, it does have a lag to it.. Don't know if a tune fixes this or not, but I don't have one, and don't want one right now anyway, so my rolling into the throttle works for me.. Good luck! Mitch |
(Post 5194341)
You must have gotten the base 3.5L engine confused with the Ecoboost.
Originally Posted by Roadie
(Post 5194345)
F150 Ecoboost vs ram 1500 vs tundra - YouTube |
I suspect you may not have an EB too. My 2014 Platinum 4x4 3.5L EB is way above the power I had in my 2005 KR with the 5.4L engine. Or, is it possible you have the 2.7L engine?
I've found it works best applying the throttle the way Mitch described. If you mash the pedal, it forces it to downshift and that takes time to complete. Just pushing the throttle in a bit aggressively but smoothly causes the boost to come on and the gearing stays higher - there's no delay and the truck smoothly accelerates with very nice acceleration. - Jack |
Originally Posted by MitchF150
(Post 5194343)
Not sure, but my Eco pushes me back in the seat and hauls effing ass either way... And it's stone bone stock.. Tows my #5000 like it's not even there.. Well, at least compared to my old 97 F150 with the 5.4 in it.. ;) I have found that it launches much better if you just 'roll' into the throttle from a complete stop instead of just mashing it to the floor the instant you want to go. I also find it does better rolling into it while running at speed too.. If I just mash it, it does have a lag to it.. Don't know if a tune fixes this or not, but I don't have one, and don't want one right now anyway, so my rolling into the throttle works for me.. Good luck! Mitch You think it would sound good with custom exhaust or does it need a 5.0 to give it some rumble? |
(Post 5194348)
I've found it works best applying the throttle the way Mitch described. If you mash the pedal, it forces it to downshift and that takes time to complete. Just pushing the throttle in a bit aggressively but smoothly causes the boost to come on and the gearing stays higher - there's no delay and the truck smoothly accelerates with very nice acceleration. - Jack So all you guys with the 3.5L, have any of you modified the exhaust? Does it sound good? I'm also thinking about adding a cold air intake. Anyone here done that? Any specific brand you would recommend? |
The base non-turbo engine is a 3.5L as well as the Ecoboost dual turbo 3.5L. Very easy to tell the difference.
(Post 5194370)
I will try to answer your question since it seems things got sidetracked by what engine you may or may not have. I've only in person heard / seen two EB's with dual exhaust, both were not bad in the sound department. Not the deep rumble you might expect with a V-8 but not ricey either. One was a Borla cat-back I think and the other was a Magnaflow, if you stay away from cheap thrown together muffler shop systems you will be fine, but like they said above, little or no power gains.
Originally Posted by Dog'em
(Post 5194394)
You think a 4" lift would be too much for the 3.5L? |
The kid that works with my son has a four inch on his 2015 with 35" Coopers and looks great, says it is a little noticeable in town and his gas mileage has dropped a couple which is common especially with mud tires.
Originally Posted by vblack
(Post 5194340)
The 3.5L ECOBOOST has more torque than the 5.0L V8. And it has more torque than the 5.7L toyota. Torque is what puts you back in your seat when you floor it. The other option is the rear end... what gearing do you have on that truck? You have a SCREW Platinum so you know its going to be heavy. What size truck was your toyota? Ford Specs https://cimg9.ibsrv.net/gimg/www.f15...2034ceaaef.png Toyota info https://cimg5.ibsrv.net/gimg/www.f15...c51a52e19d.jpg |
