Ecoboost mileage doesn't add up
I can't figure this out and after a year it hit me. The ecoboost is 3.5l. The 3.7l is obviously a large engine. Yet the smaller engine mileage is listed at 1mpg less. It makes sense that the mileage is not figured by a lead-foot kicking in boost, so what is causing this direct injected gas-sipping engine to get less mileage than it's big brother 3.7?
I'm not surprised that the engine making 302 hp and 278 lb. ft. torque gets better gas mileage that the engine making 365 hp and 420 lb. ft.torque.
Originally Posted by NASSTY
(Post 5044719)
I don't know if you get paid for the nonsense, but you should. Even you should realize how valid my point is and how irrelevant maximum power is in this issue. |
You are a moron
Originally Posted by RexReid
(Post 5044728)
(Post 5044728)
:thumbsup::banana::roflol::eek::coffee: |
(Post 5044728)
That isn't real well thought out because that is true at full throttle. Everyone knows epa mileage is done with the gentlest of foot. That's why their mileage is always higher than most people actually get.
I don't know if you get paid for the nonsense, but you should. Even you should realize how valid my point is and how irrelevant maximum power is in this issue. I think you get paid for this. Why else would 99% of your posts be crapping on Ecoboost threads when you have never owned one? I would think a 5.0 owner would contribute to a 5.0 thread once in a while. |
(Post 5044742)
So are you saying the EPA's gentlest of foot never got into the boost during their testing? If they did their is your answer.
I think you get paid for this. Why else would 99% of your posts be crapping on Ecoboost threads when you have never owned one? I would think a 5.0 owner would contribute to a 5.0 thread once in a while. I often contribute to 5.0 threads. 5.0 threads do not contain nearly the number of problems that the eco threads do. When ever someone has a legitimate problems the same people show up to change the subject, make personal attacks and call the problem "rare". It's pretty obvious. I do agree with you that when the epa testing is done for mileage, they never get into the boost--you probably already know that. |
Originally Posted by jdeacon
(Post 5044745)
https://www.f150online.com/forums/5042078-post40.html :coffee: MGD |
Okay... enough.
I've seen enough reported posts as a result of simple posting and it WILL stop. The next overall derogatory comment - as determined by me or by my staff - will result in a vacation from the site. I'm sick of the immature nonsense. Any questions? Contact me... otherwise, stay on topic and stop the personal IMMATURE attacks. -Rockpick f150online.com Administrator |
(Post 5044714)
RP long time no see, how have you been?
Again
http://www.fueleconomy.gov/feg/how_tested.shtml The EPA doesn't determine mileage by pressing the gas like there is a baby kitten underneath the pedal, they actually have to get up to a certain speed in a certain amount of time, which heaven forbid, may involve getting into boost. |
(Post 5044762)
Again
http://www.fueleconomy.gov/feg/how_tested.shtml The EPA doesn't determine mileage by pressing the gas like there is a baby kitten underneath the pedal, they actually have to get up to a certain speed in a certain amount of time, which heaven forbid, may involve getting into boost. That's a good point. Do you think they are getting into the boost then? What speed do they have to get up to and how fast? |
(Post 5044714)
Maybe the normally aspirated motor's higher compression ratio makes it more efficient at light throttle. Maybe the EPA testing is flawed. Maybe the 3.7 mpg was rounded up by the EPA (xx.6) and the Ecobooost was rounded down (xx.4), and the difference was less than 0.2 mpg. |
Originally Posted by dirt bike dave
(Post 5044774)
Maybe cam timing has something to do with it.
Maybe the normally aspirated motor's higher compression ratio makes it more efficient at light throttle. Maybe the EPA testing is flawed. Maybe the 3.7 mpg was rounded up by the EPA (xx.6) and the Ecobooost was rounded down (xx.4), and the difference was less than 0.2 mpg. Sounds like definitive maybes to me. As to the compression ratio, I thought that was so when the turbos kicked in and raised the compression ratio, it wouldn't get to high in the eco and cause engine knock. Why do you think the cam timing matters? As to the EPA testing being flawed, that sounds really weak. Why even do it? As to your rounding point, that sounds a lot like the previous weak argument. |
| All times are GMT -4. The time now is 01:01 PM. |
