PCV elbow, more than one?
I recently replaced the leaky pcv elbow at the throttle body, but have read there may be more. Is there more on the back of the upper intake or something?
I see the pcv valve, felt the hoses and 'y', and they feel solid, not mushy like the front elbow was.
I don't hear a leak, but have the P0171 and 174 codes. Sort of hard starting also, worse when warm. By hard starting, I mean it does not start on the first couple of revolutions of the motor, like when it was new. Takes a bit of cranking.
Or if someone has a picture of the rear pcv hoses, that would be great. It's tough to see back in there. Trying to go by feel.
Getting panicky because I have several cars that need emission related work, and it's getting cold out and emission tests are due.
Thanks.
Thanks.
This appears to be a continuation of this thread:
https://www.f150online.com/forums/v6...-starting.html
On the V6, the PCV valve is in the passenger valve cover, at the back. Unless you have a heated PCV valve, the only hose coming off it goes to the TB.
