Which pulleys and part #?
Old Nov 21, 2013 | 08:33 AM
Tasca Ford Parts's Avatar
Former Sponsor
I wouldn't rule out the A/C, typically a failing A/C clutch or bearing will actually make more noise when the A/C is off.
Try turning the A/C on and see if it goes away or gets quieter.
Here's a list of the pulleys,
Upper 5L3Z*8678*BA $26.10
Lower 5L3Z*8678*AA K $25.01
Tensioner BT*85* $61.31
Don't forget the 5% coupon code "f150forum" if you order n our website.
-Steve
Old Nov 21, 2013 | 02:07 PM
2008_XL's Avatar
-Steve
Thank you Steve. Is the ac pulley replaceable? Only reason I ruled that one out is cause I had the ac redone under warrant a few times a couple years back. They replaced pretty much every part of it because it was making a screeching sound when that pulley was engaged.
Old Nov 21, 2013 | 03:47 PM
Former Sponsor
Yes it is, it's three pieces. The pulley, field and disc.
In most cases you're best off replacing all three if the pulley goes bad, runs about $115-135 depending on build date.
-Steve
