Erratic temp gauge?
Old Nov 12, 2013 | 02:45 AM
Smoky's Avatar
ok, thanks guys. I'll try those things tomorrow. I have a long trip ahead of me and need to get this figured out.
Old Nov 12, 2013 | 02:07 PM
Smoky's Avatar
Now I'm thinking I should just have my local mechanic install a new water pump and thermostat. I wonder if I should have him install a new fan clutch as well while he is at it?....because my AC does not blow cold at idle. (only under load)
Old Nov 12, 2013 | 02:12 PM
The A/C issue is more likely a refrigerant undercharge.
If you don't have the ability to test your fan clutch, your mechanic should be able to.
With the engine OFF - the fan should spin quite freely with a cold engine, but if the engine is hot, it should be quite difficult to move.
Old Nov 12, 2013 | 02:56 PM
Smoky's Avatar
By hot do you mean normal operating temp or when my temp gauge pegs? I'll test it right now.
Ok I tried to spin the fan with engine cold, it does turn but only a few inches before stopping...seems a bit stiff. Is it supposed to spin a few revolutions?
Now I'll drive it to the hill with a steep incline and when the temp gauge pegs I'll shut off the engine and try to spin it.
Old Nov 12, 2013 | 04:12 PM
Smoky's Avatar
I'm back from my test drive. When my temp gauge pegged I immediately stopped the truck and tried to spin the fan. It actually spun easier than when the engine was cold. Can I now safely assume that I need a new fan clutch?
Old Nov 12, 2013 | 04:36 PM
Yep! With a pegged temp gauge it should be almost completely locked up.
Another option would be an electric fan conversion.
Old Nov 12, 2013 | 04:40 PM
Smoky's Avatar
Sweet! Thanks! You guys are great.
Old Nov 12, 2013 | 07:48 PM
01 gt f150's Avatar
There is alot of things that can cause a problem. Glad you got it figured out! I was thrown off by the gauge going back to normal after a key on/off.
Good call GLC
Old Nov 12, 2013 | 10:41 PM
That's because the gauge is more of an idiot gauge than a true gauge. As the engine warms up, it slowly climbs to about midpoint. It STAYS there till a certain temperature (definite overheating) is reached and then immediately pegs. When the temperature drops below that exact point, it goes right back to 1/2.
Old Nov 12, 2013 | 10:48 PM
01 gt f150's Avatar
Yeah but his lazer readings are so close to mine and I'm not remotely close to overheating. Crazy... learn something new everyday. Thanks.
Old Nov 13, 2013 | 02:52 AM
Smoky's Avatar
I'm sure I wasn't pointed at the ideal spot with my temp gun. In my mind the actual temp was somewhat irrelevant. The change in temp during the event was what I wanted to capture. I realized I could trust the cylinder head temp gauge but it was slightly behind the the actual coolant temp. The no AC at idle was a big clue I missed.
Old Nov 13, 2013 | 06:52 PM
Smoky's Avatar
Just thought I'd post back to say that replacing the fan clutch solved my overheating problem and I also have AC at idle now too.
