2001 F150 Engine Swap
Old Dec 9, 2012 | 03:24 PM
JBS Const's Avatar
I have 2 2001 F150's. The one has a blown triton engine with an auto trans and 4x4. The other is 2wd, Manual, 6 cylinder. Will the 6 cylinder fit in the truck with the blown triton and mount up or would that not be worth the hassle? Thanks for any advice
Old Dec 9, 2012 | 05:20 PM
The V-6 will not bolt to the V-8 transmission, and the V-6 transmission will not bolt to the 4wd transfer case. That's before you even start talking about electrical issues.
Old Dec 9, 2012 | 06:12 PM
coobies5's Avatar
aren't auto v6's 4r70 too? (not in op's case, but if it were a auto v6)
Old Dec 10, 2012 | 01:04 AM
Yes they are, but the bellhousing bolt patterns are different. The V-6 uses the Windsor pattern. The tailshafts are different between 2wd and 4wd.
Old Dec 10, 2012 | 08:27 AM
Veteran: Army
Stop trying to "save" money DUE TO LACK OF INTERCHANGE you'll be better off replacing the 4.6 or 5.4 so figure out which truck you want to drive and fix that one properly
Old Dec 10, 2012 | 12:13 PM
Yeah, it would be a lot easier to go to the boneyard and get a used 4.6. Cheaper in the long run too, and you will still have a usable 2nd truck.
