99 f150 4.2 Cam sprocket removal, help
Old Aug 11, 2012 | 12:16 AM
D Ryan's Avatar
I need to remove a cam sprocket long with the crank sprocket to get the chain off, the crank sprocket will slide but the cam sprocket will not! Book says it will slide off but that not happening.
Anyone help with this removal?
Old Aug 11, 2012 | 12:50 AM
1997 lariat 4.6's Avatar
Get a gear puller, we had this issue on a dodge.
Old Aug 11, 2012 | 01:24 AM
D Ryan's Avatar
Thanks for the push!
Had to take the puller apart for the fit!
Got it!
Pict of the setup:
http://www.flickr.com/photos/1813031...in/photostream
Old Aug 11, 2012 | 01:28 AM
You are welcome! Sadly I can't get it to load from my iPad, I'll check it out later!
Old Aug 13, 2012 | 11:38 AM
D Ryan's Avatar
Also had to pull the drive gear for the balance shaft, I don't know if this is the right tool but it did work, it came off easy!
