Eco and Towing
At this point your arguments kind of a mute point, bc you already said you are going diesel which is what I would do to if all I used the truck for was to tow. That's just the smarter choice.
The whole purpose of the EB is for average guys that need a truck, to occasionally tow stuff and other wise just might be using the bed or may even be completely unloaded and drive it as a DD where the fuel economy benefit kicks in. You will never see the 3.5 EB in a SD truck, bc chances are if you have a SD you tow a lot more and you will get a diesel. Its all based on a need and desire so get what fits what your needs are, I think that's why we all have trucks, that why I bought mine, I was tired of borrowing.
Thats why I like the Big V8 in the 150. Don't need a 250 but want an engine that I can use for towing for many years. I just feel the turbos on the eco will be hotter than hell when under load for 7 or 8 hours towing and I like the f 150 ride better than the 250. To each his own but I will stick with the 8.
If this happens it will be a BEAST!
X2 total domination.
I just heard the other day that the corvett is gonna get a TT V8 in a very small displacement (under 4.0 L) That would be great all the features of the EB and you still get the v8 rumble. Can't wait to see what will unfold.
That would be an animal but I have yet to see anything official on this, just a lot of rumors. I figure a perfect replacement for the 5.4 in the Shelbys. A great truck engine too, id guess a pretty pricey option.
What does make sense it so punch the 3.5 out to ~4.0. The 6.8L V10 had 362 hp/ 457 lb•ft. The 3.5L EB isn't too far off of this already. In a SD the turbos could be noisier and still be acceptable which should put it nearly equal. A little more displacement would put it over.
I betcha that the EB in the 2wd reg cab, even with the long bed, would be a screamer - it would come with 3.73 gears because of the max tow package!
You are totally correct in respect to the 6.2. My point is - if you want an EB in a 2wd reg cab XL, you have to get a long bed with max tow. Otherwise, you are limited to the 3.7 or 5.0. This *IS* an Ecoboost thread, right?
Mitch
Well I can say the numbers from the EB are impressive. They are very close to the Lighting numbers back in the day the lighting was rated at 360HP and 450 ft puonds then they upped the HP the last few years of the run to 380hp at the same torqe. It would be nice to see them offer the EB in a reg cab short box but of course that wont happen.
