i was thinking 3.73's and a ls spool
Old Mar 31, 2001 | 01:37 AM
superfreak's Avatar
Post i was thinking 3.73's and a ls spool
i was thinking of getting 3.73's and a limited slip spool, i think that would give me the get up and go i need, i also wanted to get the supercoupe heads, and port them out and put roller rockers on them that should give me a hell of a jump in torque, with the headers it would be awesome.
Old Mar 31, 2001 | 08:03 AM
road_rage1's Avatar
Post
spools suck i had one and it wouldn't unlock sometimes would drag tire around corners.
Mods:
Smitty Built:Brush guard,Nerf Bars
Jacobs Ignition
Fabtech leveling kit
Pro comp extra travel shocks fr+ba
Micky Thompson Mtx 185/75r16
hypertech super chip
Rancho 2" blocks+add a leaf
Moble 1 synthetic 0w30 oil
Red line atf and rear end lube
performance accessories 3" body lift+gap guards
Pioneer p2000 and kenwood 100x4 amp, planet audio 5x6 fr 6x9 in rear
Machanical water and oil guages+tach
bed liner, Swiss Cap
80/100w superblue headlamps
4.10 rear end gears
Hellwig rear antisway bar
Old Mar 31, 2001 | 05:22 PM
Crotteau's Avatar
Post
road-rage, spools are not supposed to unlock, that is their whole design. They are supposed to keep your axles locked together at all times, no matter what, unless breakage occurs. OFF-ROAD magazine just installed and tested a spool in their tow rig, you might want to check it out (April issue I think) They had some really suprising results.
See you guys later
Old Mar 31, 2001 | 10:03 PM
powerlifter405's Avatar
Post
a real spool WILL "LOCK" THE TWO AXLE SHAFTS TOGETHER.
Bet a powertrax unit. Easy to install, acts open on turns but locks when there is slipage.
gears are always an easy way to restore umph.
Cheaper than a blower or heads.
--that sounded bad didn't?!---
Old Apr 1, 2001 | 01:49 PM
superfreak's Avatar
Post
i was gonna try the limited slip spool, that way it would only lock up when i got on it, i found a set of supercoupe heads, that will be fun
Old Apr 1, 2001 | 03:58 PM
max mitchell's Avatar
Question
April Fools Math Lesson:
SPOOL+LS=TWO DIFFERENT THINGS
Old Apr 1, 2001 | 07:53 PM
superfreak's Avatar
Post
well i meant the whole unit, i know spools lock the axles together, i meant the whole assembly in the differential, bad wording
Old Apr 1, 2001 | 07:55 PM
superfreak's Avatar
Post
actually i am right,. look at the jegs catalog under richmond gears, and look for the limited slip SPOOL kits.
Old Apr 2, 2001 | 02:45 AM
ILUVNOS's Avatar
Post
The new generation Detroit lockers are of the limited type. They unlock in turns..if only i could find one for the 8.8...all I seen to be able to find is 9". Scrath that, here it in front of my face, 489.99, heh.
Old Apr 3, 2001 | 09:39 AM
Y2K4.2XL's Avatar
Post
Is your truck already trac-loc? If it is, I can share a rebuilding trick that Mustang guys use to make it lock a lot tighter.
If your truck is not trac-loc, you can buy a factory trac-loc carrier for your truck for around $200. Then before you put it in you can add a friction to it, to make it tight like I was talking about above.
Detroit lockers are LOUD and obnoxious when you turn, but they do lock tight , and they are VERY strong.
A true spool doesn't belong on the street. It won't allow your tires to turn at different speeds during cornering. This results in severe "push" during turns when it's dry, and unexpected "fish tailing" when it's raining.
2000 F150 XL Reg Cab 4.2 Auto 4x2 Red&Silver/Grey - Sony ES CDX-C7050X Deck, Cerwin Vega 6 1/2" Components (front) powered by a Kenwood KAC-S426 (50x2 rms). Two MTX 4000s in Q-Logic truck boxes powered by a Coustic AMP-360(70x2 rms)
00 Mustang GT Coupe White/Graphite all stock (for now)
88 Mustang LX Coupe 7.59 @ 91mph 1/8th mile
Mike
Old Apr 4, 2001 | 07:30 PM
Crotteau's Avatar
Question
Hey there Y2K4.2XL, I like the idea about strengthing the factory trac-loc. My only question is about adding "a friction" what does this mean? I am really curious about how to do this conversion.
Thanks much
Old Apr 11, 2001 | 01:35 AM
superfreak's Avatar
Post
hey yeah how do you add "friction" to make the stock carrier lockup?? you saya factory on can go in??? what about all that computer bull**** to??will that matter or will it act just like a ls??
Old Apr 16, 2001 | 09:59 AM
Y2K4.2XL's Avatar
Post
If you are familiar with the internals in a trac-loc differential this will make sense to you, if you are not then it probably will not.
In the factory carrier Ford puts three friction plates, and four steel plates in each side of the carrier. They are stacked as follows ("f" is for friction plate "s" is for steel plate):
Stock order: f, s, s, f, s, s, f
The preferred order is: f, s, f, s, f, s, f
In order to do this you have to have an extra friction plate(from your dealer), and just remove one of the steels. I couldn't believe how much this helped mine.
I'll see if I can find you guys some good links for this info.
Old Apr 16, 2001 | 10:24 AM
Y2K4.2XL's Avatar
Post
I copied an article from http://oldwestracing.com/ courtesy of Chris Neighbors and Paul Campbell
<font face="Verdana, Arial" size="2">
Traction-lok rebuild:
A brief traction-lok description: The t-lok, IMHO, is a very simple yet effective method of torque transmission. It uses a combination of frictions and steels; the steels spline to the O.D. of the side gears (the I.D. is splined to accept the axles), and the frictions keyed to the differential case (driven by the ring gear) with tangs. An S-spring is used to provide initial clamping load, then is supplemented by the outward forces created and transmitted by the pinion gears.
If you plan to rebuild the traction-lok, it is advisable that you do it now, for a couple of reasons: 1. Going to a numerically higher gear ratio, the pinion diameter goes down, and the ring gear thickness goes up. What does this really mean? The S-spring “gap” between the side gears is partially blocked (straight line of sight) by the thicker ring gear (you can still get the spring in, it’s just a bit tougher). 2. Without the ring gear, you can support the differential case by the flats (across the clutch cavity) on a block of wood, while driving the S-spring in place. Also, there are two approaches to component order: the factory method, and the alternating method. From the factory, t-lok’s are packed in this order: shim, friction, steel, steel, friction, steel, steel, friction, side gear. The alternating pack is as described: shim, friction, steel, friction, steel, friction, steel, friction, side gear. There is some debate on the durability of the alternating method, as you have reduced the number of splined components (thereby increasing shear and contact stresses), while increasing the ability to transmit torque. My contention? I’ve never seen a rearend go out due to t-lok spline failure; it’s usually axle related (OK, at some point the axles become stronger than the steel splines; at which point, I don’t know! Maybe somebody ought to “run some numbers”…). Both methods work: satisfy your particular needs and plan accordingly (I prefer and suggest the alternating method, FWIW.). The F5AZ-4947-BA kit will allow you to accomplish the “factory” set-up; for the alternating, you can buy a pack of frictions (see number below), or reuse two (one for each side) of your best existing frictions.
The rebuild: Soak the frictions in gear oil for a minimum of fifteen (15) minutes (while you clean the diff case, gears, and shims) prior to assembly in order to avoid dry working and possible component damage. Be forewarned: the clutches will still pop when first driven (I about had a conniption when I first rolled mine out of the garage after gears and t-lok! The thing popped about a dozen times in turns before settling out. I soaked mine about twenty (20) minutes, but the last set I worked on was soaked for about two hours. Result: only one or two mild pops, even with alternating frictions and a new F-150 S-spring!). With the differential case on one bearing, install the .045” thick shim in the bottom cavity. Apply a few drops of gear oil to the other .045” shim and place in the upper cavity (the oil will hold it in place, as long as the drops are towards the case…). Stack the frictions, steels, and side gear (engaging steels) in the lower cavity per your packing choice, then stack the upper units on the side gear, and install as a unit (make sure tangs locate in case). Install one of the pinion gears in place, and, while holding inward with one thumb, install the opposite side pinion gear 180 degrees apart (I prep the pinion gears first by putting a couple drops of gear oil between the gear and it’s steel bearing “shell”). Pick up the whole assembly, and install on the end of an upright axle. Rotate the diff case while holding the pinions inward as hard as possible; if you’re lucky, the “assembly” will roll right into place. If the shims are too thick, the pinion gears will not clear the case (acting like a built in gauge…). Change one shim to the next thinnest, and try again. If it fails to go together, change the other shim to the next thinnest: repeat until the gears rotate into position. It’s fine to have one shim .005” thicker than the other; just don’t end up with a .010” disparity. If the pinion gears line up, and the shaft will go through, you have it correct (It took me about three tries the first time, LOL!).
S-spring installation: This is actually the most trying part of the whole procedure! The S-spring, by design, has to be compressed to allow installation. The Ford (Helm) manual directs you to tap it into place with a rubber hammer; maybe one that weighed about 1000 pounds and was frozen rock hard! More people have had difficulty with this one seemingly simple task, and I’m no exception. I fought my first one for about an hour, then finally got it by compressing it in a vise, holding it compressed with a couple of pairs of needle-nose Vise-grips, and driving it into place. Shortly thereafter, Larry Turvy from the Corral offered a great tip: use two, 2” capacity worm-type hose clamps. Larry’s original suggestion was to use the clamps to compress the spring, but I still use the vise, then install the clamps, leaving a bit of the end exposed to get the thing started. Place the compressed spring into position, and start driving it into place with a hammer. With all luck, the spring will start in a few blows. Continue driving the spring in, until you stop on one of the “worm” portions of the clamp. Cut this clamp out with aviation or tin snips (Dremel or hacksaw may work), and continue driving, removing the other clamp when required. (Note: I found a 6-8” long piece of 1” x 1-1/2” rectangular tube, used as a “punch”, to be very helpful in “persuading” the S-spring into position, especially when using the F-150 unit!). Be careful not to drive the spring all the way through and out the back; sight down the pinhole and roughly center the spring. Set the unit aside for the time being.
Congratulations! You’ve just completed the Traction-lok rebuild (successfully, I hope)!
</font>
If any of you guys still need more info let me know, I may be able to find more.
Old Apr 17, 2001 | 01:06 AM
superfreak's Avatar
Post
man, that sound like a really fun project, that would be cool, now i got one more why does this trac lok have all the computer stuff with it? dont understand,
