engine removal
Old Jun 16, 2000 | 09:17 PM
agmantoo's Avatar
Post engine removal
Has anyone on the forum got any experience in removing a 4.2 L? Is there anything in particular that I need to watch for? The engine seems to be located very far back and the lifting eye on the drivers side is not very accessible. Will I need to removed the intake prior to removing the engine? TIA
Old Jun 17, 2000 | 11:41 AM
snow white's Avatar
Question
I have no idea how to take out the engine, but I must ask you, why are you taking out your engine?
2000 White sport
4.2l V6 5spd
K&N filter
e-mail: XLR8@f50guy.com
Superchip
Single in dual out 40 series Flomaster
As soon as i can afford it: Airaid FIPK
Old Jun 28, 2000 | 09:49 PM
agmantoo's Avatar
Post
The engine has been removed and replaced. The task was not too difficult but the engine is a tight fit. If the water pump is not removed prior to removing the engine it is necessary to rotate the engine 90 degrees after separating it from the trans to clear everything prior to extracting the engine.
