Vacuum Problem
Old Jul 21, 2010 | 09:59 PM
Pdman1985's Avatar
Vacuum Problem
I have a 97 F150, v-6 4.2 l engine automatic. Recently I notice the a/c going from panel to defrost. Going to Columbus yesterday as long as the engine was under light load the engine/transmission was fine but when trying to excelorate or slowly down (no braking applied) it would jerk. I suspect a bad vacuum pump but I have no idea where it's located or what it looks like. Can you enlighten me?
Old Jul 21, 2010 | 10:59 PM
There's no vacuum pump, it uses engine vacuum. Pull your battery and look at the vacuum lines behind it, one is probably cracked. That would cause the A/C issue. The tranny issue is something else, no vacuum involved, it's all electronically controlled.
Old Jul 21, 2010 | 11:21 PM
Pdman1985's Avatar
That was the fix
The vacuum line was barely making contact. I cleaned it up and taped it until I can get a replacement fitting. It doesn't jerk and the a/c doors don' change positions underload.
Old Jul 21, 2010 | 11:46 PM
You can cut out the bad section and splice it with standard vacuum hose of the right size.
