94 inline six missing.
Old Jan 11, 2010 | 09:02 PM
dmgadway's Avatar
I have a 94 f150 w/ inline 6 engine. has aprox 70,000 miles on it. was missing when traveling at a constant speed, not when idling or accelerating. i replaced the plugs(motorcraft), gapped them, replaced the cap and rotor, installed new plug wires. now the problem dosnt occur when traveling at constant speeds, it happens when coming to a stop or when your not moving and the transmission is in gear.( auto transmission.) any suggestions where to go now? Thank you for your time!
Old Jan 17, 2010 | 09:29 PM
03fordZilla's Avatar
So when it is idling now. If that is the case, I would suggest checking the IAC (Idle Air Control Valve). Could be gunked up, or simply starting to go bad. If that is not the case, let me go out on a limb and suggest checking vacuum hoses. Wouldn't know where to start if that. I hope this helps. I'm not very familar with the 300 I6, so going off of experience.
