Engine Knocks on Drive and Idle going up and down in Neutral
Old Dec 31, 2009 | 01:43 PM
desertst0rm's Avatar
I cleaned the MAF and try to relearn the idle by disconnecting the battery. I already check the intake pipe up to the throttle body but I can find any sign of leak.
The engine is not knocking when cold. But after few minutes of driving every time I needed to stop I also need to put the gear in Neutral cause it knocks so bad. Sometime engine dies.
Old Dec 31, 2009 | 03:40 PM
Check the IAC and try cleaning the throttle body. It's probably gunked up.
Old Dec 31, 2009 | 04:49 PM
Do I need to replace the IAC gasket if I remove it from the throttle body?
Old Dec 31, 2009 | 04:54 PM
Generally no. Unless you nick it or it is broken. Then again, if I were in a pinch and it broke, I'd just use some quality Permatex RTV sealent and carefully make my own gasket.
Old Jan 5, 2010 | 11:07 AM
Done cleaning it, I can still hear it idle up and down but now it's not visible looking at the tachometer. I only hear it even the A/C is off.
