knock sound when engaging/disengaging clutch
Old Apr 3, 2009 | 01:41 PM
4.2L_Guy's Avatar
X2 on that
Old Apr 4, 2009 | 06:58 PM
bewtew's Avatar
help asap
i was just about to change my tranny fluid. i checked around and guess what i found.
checking through this hole...
i discovered this
and im a little concerned about this:
the tranny mount looks secure:
and here's the new u-joint w/ rebalanced shaft:
that bolt should be tightened right?! please provide your input asap. im in the process of changing the fluid and i dont know if it's okay to put the new fluid in now or the tranny will need to be taken down to fix that, therefore just wasting the new fluid.
thanks.
Old Apr 6, 2009 | 12:05 AM
4.2L_Guy's Avatar
i discovered this
thanks.
you would think it should be tightened... tighten it bud. they wouldnt make a bolt stick out that far... its a bolt obviously it spose to be tight lol
