more power
hey fifty, I have alays wondered, do you lose any functionality or power in those accessories due to the pullies??
Notice the reference to 850 RPM? That means that your alternator will not crank out at 100% until you reach 850 RPM. On my truck, the idle speed is 650 PRM. But as long as the engine is running, I'm in no real danger of my battery dying. Every once in a while, if I've got headlights on, e-fans running, off road lights on, and I'm heating up something in the microwave....I may see a slight drop in battery voltage.
And what's up with the microwave??
i dunno exactly what brand dynos are at my school but i doubt they are crappy. I go to the university of northwestern ohio and many big companies use our dyno for testin... jegs even holds the jegs engine masters challenge on these dynos. one of the proctered classes one of my buddies is in acyually did a test of bolt on power adders and tbs's were one of the things with best results... i dunno how you explain that
I like to eat. I also have a Vector Travel Oven & Sharper Image Hot + Cold Mini Fridge.
What? Nobody else carries food with them?
what do you recomend for gears as far as brand and what not? how much am i looking at spending for a set? my truck is also a standard and i was wondering if a programer would really do as much for my truck because i kno they have alot to do with shift points...
3.73's or 4.10's programmer helps with that too.
i think with 3.73's u'll be at 2200 at 70mph.. im probably wrong.
if gas mileage is a problem then dont go bigger than 3.73
Anyways, so 3.55's are a good gear to stick with if you want to maximize MPG and power to the ground? or would 3.73 be better, as in not losing alot of MPG....
its not that i just noticed the more power, i proved it on the dyno. i dont understand how you guys can sit there and tell me still tbs's dont work because its a proven fact, not only by me but a class in my school did a sponsored test of bolt on power adders and tbs's were one of the things that got the best result!
A TBS works by giving the air and fuel more time to mix but, a 4.2 F-150 it has Multi-port injection meaning the only thing going through the throttle body spacer is air and all the spacer does is slow the air down, but hey its your truck do what you want but just dont come on hear and tell us you gained 10 hp from a TBS .
When I went to 35" tires, I notice a significant drop in mileage and that it took more to get up and moving from a stand still. The gears corrected that. The formula that I used was:
New Tire Size / Old Tire Size X OEM Gears = New Gears.
35 / 30 x 3.55 = 4.1416666666666666666666666666667
Based upon this formula, I went from 3.55 to 4.10.
