97 AC clutch
97 AC clutch
Lately I’ve been getting a loud squeal at the motor. Only happens when the heater is on. Checked around and it appears to be the AC clutch partially engaging. I’m going to check it with a squirt of water to verify. Question is: why is the AC kicking on when the heater is on at the hottest temperature? Is the clutch energized to disengage and maybe my clutch coil is getting weak?
97 F150 w/4.2L
97 F150 w/4.2L
Originally Posted by glc
The compressor will run in all positions of the selector except Floor and Vent.
For dehumidification purposes. That's how the system works.
It will clear up your foggy windows.
Think of it as an added bonus... a lot of other car/truck manufacturers don't use the A/C unless you actually press the A/C or the Defrost button.
I dunno... I don't care if it turns the A/C on or not...
In fact it is good that Ford did it this way, because it puts the compressor to use rather than it sitting idle all winter.
Does the clutch get weak over time? What causes the squeal? It's embarrassing at a stop light. What's the fix and how much does it cost and where do you get the parts and do you have to discharge/recharge the system and which one of you are going to come to my house and fix it?
