'97 4.2 Throwing P1151 Code, Need Help Please
Old Jul 3, 2006 | 03:06 PM
99_lightning's Avatar
I have a '97 F150 2wd 5spd 116k.
Truck has been sitting for about a 6 months. Put a new battery in it and fired it up. After driving for a while and putting new gas I got a Got a "P1151 H02S21" Sensor Indicates Lean code. I don't hear any vacuum leaks and from what I have searched, this doesn't necessarily mean that it's a bad O2 sensor.... I don't want to go replacing $50 O2 sensors without even knowing which one could be bad. Could a bad gas cap cause this? Coil pack and plug wires were just replaced which fixed a miss I had. Any suggestions would be appreciated as I have someone coming to buy this thing in the morning!!
Old Jul 4, 2006 | 09:53 AM
BlueOvalFitter's Avatar
Do a search by entering the words "P1151". You should get a lot of results. Good luck!
Old Jul 19, 2006 | 08:02 PM
badtothebone86's Avatar
My truck had that same problem and the dealership replaced my DPFE Sensor. That could be the problem.
Old Jul 20, 2006 | 09:26 AM
projectSHO89's Avatar
Pretty odd as the DPFE sensor throws different codes. Re-check your paperwork....
This one is an O2 sensor code upstream driver's side) that usually is old/slow/lazy.
Steve
