P0171/P0174 & Engine won't start.
Old Jul 17, 2005 | 11:21 PM
cdawley's Avatar
Hi,
I have a 99 F-150 V6 and went to replace the hose from the pcv valve to the intake under the throttle body. I couldn't find a replacement hose, so I put the old one back on there. I then went to crank the truck up and it wouldn't crank. Is there something else that could be causing the truck not to crank? Did I mess something up?
Thanks,
Chris
Old Jul 25, 2005 | 09:58 AM
bigbronc's Avatar
You didn't accidentally knock off the s terminal wire from the starter solenoid, did you? You do mean that the engine will not turn over?
Robbie
