4.2 problem
Old Jun 15, 2005 | 12:43 PM
reefbrooker's Avatar
4.2 problem
I have an electrical problem with my 97 F-150. When I start the truck the temp gauge goes all the way up, the oil pressure gauge goes up then back to nothing the fuel gauge does the same and the voltmeter goes all the way up.
Old Jun 15, 2005 | 04:49 PM
BlueOvalFitter's Avatar
Check your owners manual under the fuse section and see if there is a fuse or relay for the guages.If so,check them.If they are ok,then you have a more serious problem,which is way out of my league. Good luck!
Old Jul 11, 2005 | 02:45 AM
davisote's Avatar
4.2 problem
Check your truck grounds, usually erratic readings at the instrument cluster are ground problems. Check your negative cable from the battery to the chassis. The ground wire between the engine and the fire wall, etc.
Davisote
Old Jul 11, 2005 | 05:05 AM
texas_fordlover's Avatar
Curious, mine has been doing this for well over seven months...I can't seem to find anything that it is harming except possibly my own ego. Checked the procedures on here and didn't fix it but I'm sure the grounds needed to be cleaned anyways.
