engine code help!!!
Old Feb 10, 2005 | 02:39 PM
ampresearch's Avatar
engine code help!!!
hey there ya'll.
long time no speak. anyhow.
awhile back I had a new engine installed. Two days after it began to run funny. Today finnaly it threw out an engine code.
The engine code is p0300 which from what i can tell is muti cyl misfires.
here are my trucks symptoms. I have been paying very close attention.
When I start the truck somtimes it will start hard, as in it will jump to a start with a shutter.
when I step on the gass hard it will sputer for a few seconds and then go just fine.
it will NOT do it when rpm is higher then 2500.
it does not seem to matter what speed i am going. if i have very steady gass it will be ok with only random shutters. if i step on it quickly it will worsen for a second and then jump to life.
here is a really strang symptom. if i let the truck sit for a few days without driving it it will take a good day of driving to start acting up again,
first thing in the morning when cold it is not as bad as when i have been driving around for a bit.
when i first get out of the truck i can smell fuel.
any info or ideas on where to start would be great.
Old Feb 12, 2005 | 07:54 PM
bigbronc's Avatar
P0300 is random misfire. The pcm knows it's missing, but can't pin it down to a cylinder. It could be numerous causes. Plug wires, coil, intake leaks, egr gases when not needed, plugs, hard to say from reading symptoms like yours.
Robbie
Old Feb 12, 2005 | 07:55 PM
bigbronc's Avatar
Check plug wire routing and make sure they are installed snugly and on the right cylinders.
Robbie
