Help Needed
Old Dec 15, 2004 | 11:55 PM
bojanglys's Avatar
Help Needed
Ok here is el problemo...I have a 00' 4.2, and the pwr steering moans and vibrates like the pump is bad, but my mechanic said the pump was fine..So what I need to know is; if there is a some conditioner, or maybe a new hose that will make it stop, cus frankly...it is taking away my holiday cheer.
Old Dec 16, 2004 | 08:51 AM
ffdemoss's Avatar
Use your wife's turkey baster to suck out the old fluid and replace with synthectic. Then start truck and repeat 3-4 more times to get all the old fluid out. It will quiten it down some. You'll be happier...but the wife may not be.
Old Dec 18, 2004 | 02:21 AM
Mr_Bentwrench's Avatar
you could try running some seafoam trans tune in the p/s then drain and refill the resivoiur. also look around where the pressure line goes into the pump from underneath. it could be leaking there letting the pump airate.
