Starter problem
Old Jan 6, 2004 | 11:05 PM
BlueOvalFitter's Avatar
Unhappy Starter problem
Went to start my truck this evening and all I got was a click. Battery is ok,coolant level good(lowers changed 11/02) lights working,etc. I then kept trying to start it and after 4-5 clicks it finally started. Drove it home,and it started several times with no problem.Corroded wires maybe or bad starter? Any opinions?
Old Jan 7, 2004 | 12:34 AM
paulv107's Avatar
Have you checked the battery terminals and connections? Corrosion on them might cause that. Might not be getting a good connection. Also check the ground strap going to the starter. My moms car did that a while back, but only it would not even click. Sometimes it would crank and sometimes it would do nothing. Those are two suggestions.
Old Jan 7, 2004 | 10:37 AM
Peacemaker's Avatar
Yeah, I'd check what paulv107 said to check. More than likely it's the connections that are corroded or loose.
Old Jan 8, 2004 | 07:19 AM
Fixed it yesterday morning.Was a loose connection at the starter.Thanx for you responses guys!
:santa:
Old Jan 8, 2004 | 09:33 PM
Peacemaker's Avatar
Glad you got it fixed.
