codep303
Old Sep 14, 2003 | 05:32 PM
jw128's Avatar
codep303
have 1999 f-150 4.2 liter,with codep303. have replaced fuel filter,egr,plugs&wireswith no help.what is the firing order& what else could cause the missfire in cylinder?
Old Sep 16, 2003 | 09:08 AM
SaltWaterFish's Avatar
I found this on the net. Hope this helps
http://www.visi.com/~rhanson/obdII_codes-full-text.htm
Old Sep 16, 2003 | 09:17 AM
The firing order is 1-4-2-5-3-6
You may have a bad head gasket, not sure. Check your coolant level.
Old Sep 17, 2003 | 03:14 AM
digraceready's Avatar
missfire
I got that code on my 97 f-150 4.2 missfire #2 turned out to be coil....this was before it started knocking.....
