Elec fan install compleat
Old Aug 12, 2003 | 10:24 AM
SPROCKET_X's Avatar
Originally posted by 01 XLT Sport
When I first test drove it I wanted to insure it “really” had the 3.55 limited slip.
Just an FYI but that still doesn't mean you have a limited slip....a non-limited slip can smoke both tires and leave equal marks as well. Just look in the door jam...the sticker doesn't lie, or I have yet to see one that does.
Back on topic I also installed the Troyer fans about 2 weeks ago and am loving every bit of them.
Old Aug 22, 2003 | 10:30 AM
JMC's Avatar
JMC
25 Year Member
Fan removal tool
FYI; you can use a long (12 in.) flat screwdriver wedged between 2 bolts on the water pump instead of the tool. The fan comes off in a counterclockwise rotation.
Regards
Jean Marc Chartier
Old Aug 25, 2003 | 04:39 AM
BroncoAZ's Avatar
I still haven't had time to get these installed. They're starting to get dusty I sure could use that extra MPG. I'm averaging about 16 right now in mixed driving. Maybe it'll increase if we can ever get the chip figured out.
Mitch
Old Sep 7, 2003 | 11:39 PM
BroncoAZ's Avatar
I finally got started on mine. That ****** fan clutch was a bear to remove. I rented the tool from autozone, but I still couldn't get it. I finally took the torch to it and was able to get it off. It was on there super tight. I got the fans mounted, and will do the wiring tomorrow. I've got my own ideas on how to setup the wiring as opposed to following the Troyer instructions. There is an AC part where they suggest mounting the fan relays.
Mitch
