Clutch/tranny??
Old May 13, 2003 | 12:43 AM
powerdome's Avatar
Clutch/tranny??
Hey ya'll i have a couple problems, i hope they are just normal, but anyways, when i was in the parking lot today when i would engage my clutch, i would hear this suddle clanking sound coming from underneath the cab, and when i would fully engage the clutch i would never hear it again. Thats my first problem, the second one is when i am at interstate speeds 75-85, when i let of the gas, i get the innitial jolt from the slack in the driveline, then i get this suttle shimmer and its the same every time, about a 1/4 of a second after the initial jolt in the driveline, could this be a faulty U-joint? syncro's? please help warranty is out soon!!
Old May 13, 2003 | 08:37 AM
road_rage1's Avatar
sounds like u-joints put truck in gear and have someone roll it while you look under. engine must be off.
Old May 13, 2003 | 08:34 PM
powerdome's Avatar
what do u mean by the engine must be off?
Old May 14, 2003 | 08:25 AM
road_rage1's Avatar
you want the trany locked no motion when you move truck back and forth by hand you should be able to see where the slop is at
Old May 17, 2003 | 06:46 PM
Hotshot's Avatar
I have had the same problem. You need to take it in before the warranty is up. There is a problem with one of your sensors.
Old May 18, 2003 | 11:06 AM
powerdome's Avatar
I gotta appointment at 9:30 in Omaha to get it fixed, thanks alot this will speed up the repair cuz i have some sort of idea, thanks alot.
