Water Pump
Old Feb 10, 2003 | 04:53 PM
Dadstruck's Avatar
Water Pump
Hey everyone, i am new to this forum, My dad has a 94 F150 V6 and his water pump just went, he is in the middle of it and he can not figure out how 2 get the pump apart from the fan assembly? anyone know how to do this? any information would help. Thanks alot guys
Old Feb 11, 2003 | 04:46 AM
BoostedOne's Avatar
A 94 with a V6?
According to the manual for the I6...
1. Remove the fan shroud (8146).
2. CAUTION: The large clutch assembly nut has a right-hand thread and must be rotated counterclockwise to remove it.
Remove the fan clutch (8A616) from the water pump (8501) by turning the large nut, which is part of the fan clutch, using Fan Clutch Holding Tool T84T-6312-C and Fan Clutch Nut Wrench T93T-6312-B.
3. Remove the fan blade (8600) and fan clutch.
4. If the fan blade and fan clutch have to be separated, remove the remaining bolts attaching the fan blade to the fan clutch.
I used a 12" Crescent wrench on the nut portion, and I vice gripped the pulley. Later I ground the burrs off the pulley. A better method to hold the pulley would be a strap wrench if you have one.
