How many quarts in the trans
How many quarts of transmission fluid will I need to do a complete fluid change??(including the torque converter). I found one post where it was mentioned 14 quarts. Is that the correct amount? Will be doing the change myself this time because I want to use a synthetic blend.
thanks.
Black 1997 F-150 Supercab Flairside. 4.6L with Superchip, Jacobs DIS, K&N Generation II, Cat back Exhaust with Flowmaster 40 and MEG'S Stainless tip in front of rear wheel (nice rumble). 17" Off Road wheel pkg. Lots of body mods. 5 yrs old and still turns heads...and now paid for!! New is NITTO NT404 275/65/17's and Hellwig 1/7/16 front and 1 1/8 rear bar.
thanks.
It takes 13.9 qts., but only add small amounts when you get close to compensate for trapped fluid.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 4.10LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Pirelli Scorpion Zero 275/60/16s, Mobil 1, K&N oil filter.
That sounds about right from what I can remember when I did mine, according to the owner's manual. Your owner's manual does have the exact amount in the capacities chart. Just remember on our trucks, you can drain the torque converter (which holds LOTS of fluid). If you don't drain the converter, and only do a "pan-drop" fluid change, you will only get about half of it out. You might also find a little plastic acorn shaped piece floating around in your tranny pan - don't worry, it's supposed to be there, just throw it away when you put it all back together. Hope this help.
1997, F-150, XLT, 4X4, SuperCab, 4.6L, Auto, Factory Towing Package, White Ext with Blue Int.
* 3" Performance Accessories Body Lift
* 33X12.50R16.5 BF Goodrich All-Terrain K/O's
* 16.5 X 9.75 Eagle 1439 Wheels
* K&N Filter
* Rockford Fosgate CD Head Unit
* 4 Rockford Fosgate 5 X 7's
* 20% Window Tint All Around
questions to brett@tiremolds.com
* K&N Filter
mine took 11 quarts including torque converter
97 F150 XLT: Two-Tone Green and Tan, V6 4.2L Auto Trans 4X4, 3.55 gears, 265/75/16 Dueler AT's, Edelbrock Performer IAS Shocks
MODS:Airaid FIPK, Superchip, Ravin Z55 Exhaust SI/SO
GOODIES:Kameleon Head Unit w/12 disk cd changer, JVC 4ch 560watt poweramp, Bazooka Tube, Boston Acoustic 5x9's, Tinted Back, Westin Nerf Bars..
