C6 bell housing
Old Jun 28, 2001 | 08:41 PM
dvldog458's Avatar
Question C6 bell housing
Does anyone know if the bell housing bolt pattern is different from a 302 C6 to a 351 C6?
Or is it just different from small block to big block?
Jerry D
Old Jun 28, 2001 | 10:04 PM
max mitchell's Avatar
Cool
You measure between the top 2 bolts.
5&1/8" C6=289,302,351C,351W
6" C6=332,352,360,390,406,427,428
7&3/4" C6=429,460,351M,400M
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 4.10LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Pirelli Scorpion Zero 275/60/16s, Mobil 1, K&N oil filter.
Old Jul 3, 2001 | 01:33 PM
dvldog458's Avatar
Max,
Where did you get your info fom?I'm trying yo settle an argument with my friend about this subjuect.
Old Jul 4, 2001 | 03:51 PM
dvldog458-
The information is correct. Tell your friend I was around decades ago when these engines and transmissions were actually used. The measurements can be found from any good transmission parts catalog or Ford transmission service manual. I got these from an older B&M catalog and double checked them with a Ford transmission service manual from the olden days.
Old Jul 5, 2001 | 11:48 PM
dvldog458's Avatar
Max,
Thanks for taking the time to look thse measurements up.
It will help us in a future engine swap.
Old Jul 6, 2001 | 07:54 AM
You're Welcome ! Happy Truckin'
