synthetic fluids ?????
Old May 25, 2001 | 09:01 PM
evan's Avatar
Post synthetic fluids ?????
I am planning on changing the fluids in my transfer case,transmission, front diff,and rear diff. should I put synthetic in it and what kind? I tow a 7000k boat and have been changing the tran fluid every 15k miles, and it is now time to do it again. will I get better milage after I put synthetic everywhere because I shure need it..I am getting 10mph around town and 13-15 hwy, 10 towing the boat, with summer here we are planning on traveling the east coast looking for great fishing spots around the coast and the milage is killing me..
1999 SD F250, V10,4x4,3.73gears, all the options, bright red,gibson duel exhaust
Old Jun 1, 2001 | 11:28 AM
evan's Avatar
Post
Old Jun 1, 2001 | 03:42 PM
Ian N's Avatar
Post
I doubt you will see any change in mileage (certainly the extra cost of the oil will never pay for itself) but the synthetics will give you more protection when towing.
Ian
99 Expedition EB
5.4l, 4x4, 4.10 LS
WMS Tube, Bassani Cat Back Exhaust, Superchip Flipchip, PIAA Superwhites
Old Jun 1, 2001 | 06:27 PM
msparks's Avatar
Post
Actually synthetics will pay for themselves if you use the right kind.
Amsoil synthetic ATF is recommended at 3 times the drain interval compared to conventional ATF. So that equals less change outs, saves time and money.
Amsoil has a short term temp rating of 375 degrees. Once your conventional fluid overheats you run the risk of killing your transmission.
Even a 1 time over heat Amsoil will pay for itself 100 fold, since a transmission rebuild is over $1000 and total cost of the fluid might be $50 or so.
Synthetics carry heat away from internal parts better because of their laminar flow, less heat equals less wear.
Synthetics fluids reduce friction which reduces heat and wear! Less heat and wear equals longer equipment life.
I don't care what brand of fluid you use, but just make it synthetic!
Here is information about Amsoil and Mobil 1 ATF
http://www.amsoil.com/products/atf.html
http://www.mobil1.com/mobil1_racing/...atf/index.html
If you do change to synthetic make sure you do a 100% change out to get all of the old fluid out!
My Home Page
Lubrication Forums
Old Jun 7, 2001 | 11:00 AM
jrm1493's Avatar
Post
actually, from fluids, turbulent flows yield much higher heat transfer rates than laminar flows, because the velocity boundary layer is much fuller in turbulent flow which results in a much higher temperature gradient between the surface and freestream...
of course, i've really only studied airflows, so oil may be completely different
2001 F-150 XL SWB
4.2L 5-spd, 3.55
University of Texas - Aerospace Engineering Class of 2001
Old Jun 7, 2001 | 11:12 AM
bambino's Avatar
Cool
evan
I used Amsoil 75w140 in the rear, 75w90 in the front diff. ATF in the tcase and my 5sp tranny.
Rear on my 3.55 takes just shy of 3 litres/quarts
Front about 2.2 litres
Tcase - 2.5 litres
manual tranny - 4 litres.
hth
Bambino
Bambino Worldwide
Owners Gallery Truck #179
1999 reg cab/short box/ORP/Silver on Dk Graphite - 3.55; 4.6l 5sp; Factory Tonneau; 40 chan CB/Maxrad Antenna; Kicker amp'd sub tubes; Rockford Fosgate components up front; Custom Exhaust; Mobil 1 5w30/Motorcraft FL820s; Amsoil Series 2k in the driveline.
Old Jun 8, 2001 | 05:23 AM
gah's Avatar
gah
Smile
<font face="Verdana, Arial" size="2">actually, from fluids, turbulent flows yield much higher heat transfer rates than laminar flows..</font>
This is true, but more work is required to pump a turbulent flow compared to a laminar flow due to greater wall shear stresses on the fluid. An interesting problem! I went with Amsoil ATF and don't plan on changing the fluid for at least 50K. The truth is a quality ATF, a good cooler, and a shift kit can make a trans last 200k miles. Most transmissions fail due to neglect i.e. lack of regular fluid changes, no cooler, HEAT etc
'00 5.4L AUTO 4X4 F-150 Lariat
'98 4.0L 5spd Jeep Wrangler Sport
'95 3.8L SC Thunderbird
'02 F-350 PSD CC DRW 6SPD 4X4 Lariat (order this year)
www.hawthorn-engineering.com
