Hard upshift into 2nd on 95 automatic
Old Aug 12, 1999 | 06:32 AM
hunter-f150's Avatar
Angry Hard upshift into 2nd on 95 automatic
Started 2 weeks ago. My F150, 5.0 automatic (4x2) started upshifting hard into 2nd gear. It kind of "clunks" in. Otherwise it runs perfectly and shifts perfectly in all other gears, including OD. It's got the AOD-E tranny so far as I can tell. I've read alot of the articles, but this seems like a new topic. Anyone else?
Old Aug 12, 1999 | 03:14 PM
Post
Fluid is full and looks to be the right color. Had the 60k service done just last year, including tranny fluid. Truck now has 75k miles on it, so it shouldn't need another change for another 15K miles. Any other ideas?
Thanks!
Old Aug 13, 1999 | 12:35 AM
Tina's Avatar
Exclamation
When's the last time you checked your transmission fluid? Does it need changing??
Old Aug 15, 1999 | 07:45 AM
Tina's Avatar
Lightbulb
If it's really upshifting bad and you think there is a problem, you could try taking it to one of those transmission places. (Amico)don't know it that's spelled right?? I personally wouldn't suggest your ford dealer (I don't have any faith in their work) Let us know what happens, what ever you decide.
Old May 29, 2001 | 03:02 PM
1ToughTruck's Avatar
Exclamation
Mine does the same thing. I installed a superchip but had to remove it until the problem is corrected. It shifts hard into 2nd gear but the others are fine.
I had the transmission and torque converter flushed but it was no help. It's probably going to be a sensor of some type. I hear there's one at the end of the speedometer cable that controls the shift, but I haven't tried to replace it.
If you have your truck looked at, let us know what the problem was. Thanks
Old May 29, 2001 | 06:12 PM
tim_1911's Avatar
Post
I had the exact same problem. The tranny shop found a broken spring on the 1-2 accumulator. I have about 5000 miles on it and it's doing fine.
1994 F150 XLT Supercab, 302 V8, AODE, Flowmaster 40 series, K&N FIPK
