Trans. cooloer fittings?????
Old May 16, 2001 | 11:05 AM
01X's Avatar
01X
Post Trans. cooloer fittings?????
Is there a trans cooler that uses either oem style tubing fittings or regular tubing fittings? This would help to avoid any leakage problems and make for a much nicer looking installation. Thanks
Old May 16, 2001 | 02:38 PM
F150Tony's Avatar
Post
Not that I know of...On mine, I used Hayden's adapters (Pep Boys) to adapt from the original "Flare" type fittings to hose. Works fine for ~last year, no leaks, only molecular migration wich is normal for Automotive.
Hope this helps.
Tony
