Cooling fan on trans cooler anyone?
Old May 14, 2001 | 05:35 AM
gah's Avatar
gah
Question Cooling fan on trans cooler anyone?
Went off-roading this weekend and had to climb 1500' in 1.8 miles before getting to the trail. Air temp was about 85F at the time. My trans temp gauge showed 220F as I neared the top of the hill, probably due to the lack of airflow through the trans cooler. I was thinking about adding a cooling fan to the trans cooler that I could turn on/off with a cab-mounted switch. Has anyone done this? Can anyone recommend a particular brand?
Thanks for any help.
'00 5.4L AUTO 4X4 Lariat (Black/Silver)
'95 Thunderbird SC
'02 F-350 PSD CC DRW 6SPD 4X4 Lariat (order this year)
www.hawthorn-engineering.com
Old May 14, 2001 | 01:08 PM
Neal's Avatar
Cool
HI!... ME!
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, PERMA-COOL external tranny filter, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.52E.T * MPH - 93.73 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
Old May 14, 2001 | 01:23 PM
gah's Avatar
gah
Smile
Neal,
to be honest I've never read all the way through your signature before ... but I managed it today ....
<font face="Verdana, Arial" size="2">PERMA COOL 14"/10" tranny cooler with 10" electric fan, PERMA-COOL external tranny filter</font>
I'll check out their web site but I have a couple of questions.
1. Do you have the fan controlled by a thermostat or an on/off switch?
2. How much "work" is required in attaching the fan/shroud to the trans cooler?
3. Do you recommend upgrading the cooler before attaching the fan or is the stock one sufficient?
Thanks as always,
gah
'95 Thunderbird SC
Old May 14, 2001 | 09:01 PM
Neal's Avatar
Cool
HI!... GAH : My tranny cooler fan is operated from a manual lighted switch that I installed into my tranny temp guage, guage pod. The 10 inch electric fan was designed to work with the PERMA-COOL tranny cooler so it bolted right up. The factory cooler in my opinion is junk and that is why I upgraded to the PERMA-COOL. Plus the factory cooler is WAY to small to mount the 10 inch electric fan. Hope this helps you out.
Old May 14, 2001 | 09:19 PM
gah's Avatar
gah
Question
Thanks Neal. Is this setup from Perma-Cool similar to what you have?
#12311
I'm going to look at my cooler tonight to see if the factory mounting locations will work with the Perma-Cool unit. I did notice that the inlet and exit on the Perma-Cool are 90 degrees out of phase with the OEM unit. Was this a problem for you?
Thanks.
'95 Thunderbird SC
Old May 16, 2001 | 12:49 AM
Neal's Avatar
Cool
HI!... GAH : That is the exact same set-up that I have on the PERM-COOL site. I totally removed the stock tranny cooler. I mounted my new tranny cooler on the driver's side in front of the rad. It is suspended from two aluminum mounting tabs from the upper rad cradle under the rad front shroud. I then used another long mounting tab to secure the cooler from it's middle to the lower rad cradle. I then re-did all the factory trans lines with RUSSELL -6 stainless steel braided lines and fittings. I have pics, but no way of posting them. Sorry.Hope this helps you out.
Old May 16, 2001 | 04:13 AM
gah's Avatar
gah
Smile
Thanks Neal. I'm going to order the model you have from Summit Racing but I won't be using the braided stainless lines ... too expensive and I need the money for other stuff first.
I'm amazed that your truck gets to 60mph in 5.8 seconds WITHOUT a S/C. Incredible!!
You give us all something to aim for, although I'm more interested in setting up a good tow vehicle so I'll be going with 4.10 gears and Gibson exhaust.
'95 Thunderbird SC
