452 speed sensor problem
Old May 5, 2001 | 09:00 AM
jimwall's Avatar
Post 452 speed sensor problem
1994 F150 with 4R70W transmission. Overdrive "OFF" light flashes on gearshift but only sometimes. Pulled codes and got 452 vehicle speed sensor problem. Changed speed sensor on differential but still have problem. As before, it is intermittent. Is there another speed sensor that is giving the problem? Is it a transmission problem?
[This message has been edited by jimwall (edited 05-05-2001).]
Old May 5, 2001 | 09:37 AM
T Ellenberger's Avatar
Post
A friend with the E40D had the blinking light and the dealer also replaced a speed sensor that went to the speedometor.
It was outside the transmission.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks,Expedition Center Console
Old May 8, 2001 | 07:08 AM
jimwall's Avatar
Post
The sensor that I changed was the one that went to the speedometer. The speedometer is a little erratic also.
<font face="Verdana, Arial" size="2">Originally posted by T Ellenberger:
</font>
