Tranny Shifting issues
Old Apr 3, 2001 | 10:50 AM
Tommy Tritonium's Avatar
Question Tranny Shifting issues
I just installed my airraid kit the other day, and I am not sure if it is related, but now when my tranny shifts from 1 to 2 or 2 to 3rd, the revs stay for a moment at 5000, and then about a second and a half later or 2, it finally grabs, and the revs drops back down again...what is the deal?
'97 Expedition Eddie Bauer, Airraid Intake
Old Apr 4, 2001 | 12:58 AM
Neal's Avatar
Cool
HI!... That would be FORD's famouse "GRANNY" shift!LOL! Do yourself a favour and get a SUPERCHIP or a mechanical shift kit like one from BAUMANN ENGINEERING.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
Old Apr 4, 2001 | 09:35 AM
max mitchell's Avatar
Cool
The shift lag and overlap is designed that way; TOO MUCH
Old Apr 4, 2001 | 11:11 AM
Talking
Well, that sucks...What is a good resource for learning about the different shift kits etc that are available, and is that something I could do on a Saturday in the driveway?
Thanks!
T
Old Apr 4, 2001 | 01:22 PM
Cool
Easiest way to change it is to buy a Chip; firms it up and adds HP (excellent approach on a computer controlled vehicle). You can also use with, or instead, a shift kit. This requires a trans-valve body removal/modification.
Old Apr 4, 2001 | 02:28 PM
cigarxtc's Avatar
Question
Tommy,
Which transmission do you have in your Expedition?
97 F150 Reg Cab Short Bed
4.2L Auto
Current Performance mods=
Accel 9000Series Race Plug Wires
Motorcraft Platinum Plugs 60 Series Heat Rating
K&N Air Filter(Modified Stock Airbox)
Flowmaster 40 Single in/out.
B&M Shift Improver Kit(highly recommend!!)
Current Musical Improvements=
California Profile3600 running two front Pioneer5x7 three way speakers and a single 10" Cerwin Vega in my homebuilt port tuned box.
Pioneer Cassette/cd control head unit with matching Pioneer 6 disc changer.
1/2 Farad Stinger cap.
My other truck is an in the works 1950 Ford pickup.
Old Apr 4, 2001 | 03:17 PM
Question
Well, it is a 5.4, so I think it is the 100... Is removing the trans/valve/body whatever tough to do?
Old Apr 4, 2001 | 07:17 PM
Cool
Tommy- It's not complex if you have basic mechanics skills and tools. They come with instructions. Most Transmission shops will also install these. The valve body is unbolted after removing the pan and filter, partially disassembled, and modified. Depending on the vehicle/transmission, they include valves, springs, and separator plate modification techniques.
Old Apr 11, 2001 | 04:50 PM
jwill1's Avatar
Talking
I used the TransGo shift kit. It came with a install video. Took two hours to install. Got it from Summit.
97 XLT Flairside
4.6 AODE-W
