Questions about shift kits
Old Jan 16, 2001 | 09:10 PM
Blue_Farmer's Avatar
Question Questions about shift kits
I've read through the posts about he superchip, and the stuff about them working like they should. So... decided the way I'm going to go is the shift kit/shift chip way. I'm a college student so the $300 would be hard to come by for the superchip. What I want is some suggestions as to where to buy such a kit, and what you all think of them.
'97 F-150
XLT
4x4
auto
3.55
Ford/Duraliner drop in bedliner
K&N filter
Vent Visors & Step Shields
Old Jan 16, 2001 | 11:14 PM
Neal's Avatar
Cool
HI!... BLUE-FARMER : I would go with a BAUMANN ENGINEERING shift kit. That's what I installed in my truck, and am very pleased with it. By the way, I would also get a SUPERCHIP down the road when you can afford it. The SUPERCHIP is the best BANG for the BUCK.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Jan 17, 2001 | 01:19 AM
Post
Neal-- How much did it cost and where did you get it??
Thanks for the advice.
Old Jan 18, 2001 | 01:08 AM
Neal's Avatar
Cool
HI!... BLUE-FARMER : I bought my BAUMANN ENGINEERING shift kit from RCO ENTERPRIZES in LONDON, ONTARIO, about 1-1/2 hours from WINDSOR where I live. The U.S price for the kit was $99.95(U.S). I would advise you, if you have close to, or more than 40,000KMS on your truck to also get a B/E PREASURE REGULATOR VALVE, PART # PR-AOD-E. It's $15.00(U.S). Also a B/E BYPASS CLUTCH CONTROL VALVE, PART # BCV-AOD-E. It's $25.00(U.S). For the extra $40.00(U.S) it's well worth getting. The BCCV is known for wearing out around the 40,000KM mark. I installed all of these parts and installed the shift kit on stage 5. The highest possible setting in the kit is stage 6. It's very easy to install these two extra valves since you will be taking the valve body apart to do the shift kit. Hope this helps you out and if you have anymore questions just ask.
