shifting suggestions
what would you all recommend to improve soft shifting of my e4od trans.?i have seen kits by b&m but i am sceptical,plus i am not too keen about going into the valve body.i would appreciate any input.
------------------ 91 long box,302,auto,bosch plugs,accel,superchip,k&n filter, wires,steelhorse steps,31x10.50 tires |
Go with a Superchips computer chip. I installed one an the difference is night and day.
Check out the computerchips, in the aftermarket section and read up on what others have to say ------------------ 99 F 150 4x4.ORP,S/B 4.6 4.10 gears, Gibson 3" cat back. K&N filter. Superchip |
my trucks trans. is not computer controlled so the superchip does not help me in that reguard.i think all of them are from 93 and later.
any other suggestions? thanks for the input!!!! ------------------ 91 long box,302,auto,bosch plugs,accel,superchip,k&n filter, wires,steelhorse steps,31x10.50 tires |
You must have an AOD then, because the "E" in E40D stands for Electric. Electronic 4spd Over Drive.
------------------ 2000 F-150 Super Cab XLT 4x4 ORP 5.4liter V8, Towing Package, Rear Slider, Remote keyless Entry,3.55 LS, Black Exterior, Medium Graphite interior, manual shift 4x4. Current mods Gooseneck hitch, mud flaps and Y pipe with duals. |
The E40d has selections OD,2,1 and a cancel switch on the dash for your 91. The AOD would have OD,d,1. The AOd has a really tall OD gear, so a shift kit really helps it! Otherwise the chip helps the E40d out a bunch!
------------------ toydestroyer1@yahoo.com "Sleeper" 1993 F-150 302/e4od/355 Limited slip. dual exhuast w/o mufflers, 2 1/4" pipes, Echo Tips, Summit Racing headers, accel plugs/wires(8.6mm)/rotor/cap, hypertech powermodule, 4 degree advance,Blaster Coil,MSd 6A Ignition, TPS Mod,hopefully roller rockers in the future,possible 4:10 gear swap 5% dark tint, Ford Bed mat, Bundy Chrome Drop bumper, Wrap-around bug deflector, 2-tone tan/brown. Alpine cd player and Pioneer speakers, with tweeters No room for anything else. 1989 F-150 XLT 4x4 Future 300hp engine build! 2000 Superduty CrewCab v-10, auto,2wd. |
pastmaster, according to mike troyer, on the 91`s the e4od is "electronically" controlled not "computer" controlled. yes, the cancel switch is on the dash. again.according to mike a very few 92`s are computer controlled and from then on all are.
thanks for your input!!!! ------------------ 91 long box,302,auto,bosch plugs,accel,superchip,k&n filter, wires,steelhorse steps,31x10.50 tires |
