V-8 5-speed clunk over bumps
Old Nov 2, 1999 | 07:15 PM
OLE BLUE's Avatar
Red face V-8 5-speed clunk over bumps
I am getting a clunking noise when driving over a bump when the truck is out of gear(between gears). Anyone else getting the same thing? If so, has anyone gotten it checked out?
97 4X4 Flareside 4.6 5-Speed, Dynamax headers, Borla Cat-back, 5% Tint, K&N, 285/75/16, 16x8 Baha's
Soon to superchip, soft cover, Rancho 9000's, and subwoofer.
Old Nov 3, 1999 | 02:30 AM
shortbox's Avatar
Post
YES!
I get the same thing...when the clutch peddle is pressed, the tranny inards seem to rattle around when I go over bumps. The synchro doesn't seem to work into first either...almost to a stop light turns green, I try to get into first...it won't go in, grinds and buzzes my hand. Do you get that too? I'm taking it in soon.
99 4x4 shortbox 4.2 V6 5spd
Old Nov 3, 1999 | 03:08 PM
crash1's Avatar
Post
I posted a topic on hydraulic clutches. I am having the same symptoms. I took it upon my self to bleed the system, and I got 1/4" of air and 1/2" of foam out of it. I think I have a leak. I am unaware of an adjustment, but any air in the lines will cause the same problem.
Dealer said NPF... Losers!
Any other info would be appreciated!
Derek
'98 4.6 5-sp F-150
We've come for your Tundra.
http://www.mcmullenargus.com/gallery...ge=1165&pub=12
trixters-playground@excite.com
[This message has been edited by crash1 (edited 11-03-1999).]
[This message has been edited by crash1 (edited 02-19-2000).]
Old Nov 3, 1999 | 07:37 PM
Tina's Avatar
Exclamation
Crash: when you bleed the system, did you get a solid stream of fluid out? Meaning did you get past the air and foam? When you bleed it, you should have it set up so that if the hose tries to pull air back into itself, you have the hose into a jar of fluid and it pulls that instead of air. If you are still having problems, maybe you should get that truck in for service. Like you said, it could have a leak or something is broke.
Old Nov 4, 1999 | 12:52 AM
HCBPH's Avatar
Post
Shortbox
Almost sounds like your clutch is not fully disengaged, worth seeing is there is an adjustment on it.
As far as the clunk when out of gear, the only thing I can think of is either U-Joints problems or the yoke having too much play. The driveshaft would not be under load in that situation.
Hope it's fixed soon. Good luck
Old Nov 4, 1999 | 01:28 AM
shortbox's Avatar
Post
I'll try to bleed my clutch too...I was thinking of doing it too. The rattling is definately coming from the trans/clutch not other driveline. Maybe the clutch plate is bouncing back and forth as the air in the system compresses...who knows...weird stuff anyway, I'll let you know
'99 XLS Shortbox RC 4x4
4.2 5spd 3.55 tracloc
Wedgewood Blue
Old Nov 4, 1999 | 02:02 PM
brianc's Avatar
Post
I've got the same problem. Rattles and clunks going over bumps or railroad tracks. I think my tranny is loose on the mounts. When I start out in first I can see the entire trannsmission/transfercase assembly move about 1/4". Really frustrating. Might just be moving from the slip yoke unbinding, though. Or it could be the clutch problem that you are describing......or it could be loose lug nuts. Or maybe I can blame it on my door skins cracking.
Sorry, got on a rant there. Even with all the "Problems" I still like my truck. I hope these noises don't turn into expensive fixes later on.
Old Nov 10, 1999 | 05:35 PM
crash1's Avatar
Post
Tina,
I did a gravity bleed, and then a two man bleed, closing the bleeder on the down stroke. You do have the right idea. That's the best way for one person.
Hey, not only are you a rare breed, but extremely sharp too!!!!
Yes, I got past the foam, into clear fluid. the symptom went away TEMPORARILY.
Derek
'98 4.6 5-sp F-150
www.truckinweb.com
Old Nov 10, 1999 | 05:50 PM
crash1's Avatar
Post
Tina,
Derek
'98 4.6 5-sp F-150
www.truckinweb.com
Old Nov 11, 1999 | 07:37 AM
OLE BLUE's Avatar
Post
Crash1, are you getting the rattle over bumps or hard shifting. Just wondering who else gets the rattle. If so did bleeding the system affect it?
Old Nov 11, 1999 | 08:03 AM
wildchild's Avatar
Post
i get the same symptoms with mine. clunks and rattles over bumps. also the first gear thing when barely moving. i thought about the clutch not being depressed so now i make sure my foot is all the way to the floor before shifting into first. still happens.
also shifting into any gear i get a rough shift at best, never nice and smooth like you would think a new truck should be.
'97 f150 rc, flair side,4x4,v6,5 spd, k&n air filter
Old Nov 12, 1999 | 12:59 AM
crash1's Avatar
Post
Ahhh, smooth- like a new truck.
What a concept....
Well, the clunk I get is like I saw described. It is almost like the slave is being compressed. I don't know how else to describe it. I'll check to see what happens when out of gear.
Old Nov 18, 1999 | 06:21 PM
crash1's Avatar
Post
The clunk/ rattle is there in neutral, but it doesn't happen very often. This one may turn out
to be hard to duplicate.
Old Nov 18, 1999 | 08:39 PM
OLE BLUE's Avatar
Cool
Right it only happens when in neutral. But as someone else stated it sonds as if the trasmission is loose, or the transfer case one of the two. Any help would be greatly appreiciated.
Old Nov 23, 1999 | 04:46 PM
crash1's Avatar
Post
I was able to duplicate the problem on "washboard" bumps. I was in third, clutch engaged, brakes applied. You guys are right, it feels like like the guts are going to fall out!
