Where did you tap in for the tranny temp sensor?
I just got my tranny temp gauge (and water temp gauge), it's an Autometer #4351. I was wondering, for those who have installed one... Where did you tap in to hook up the gauge?
The business end of the gauge has a copper sensor that is about 1.5" long by about 1/3" in diameter. It has a 1/2" NPT mounting nut (whatever NPT is), is this what I use? Does is screw in somewhere?
I appreciate any help I can get, thanks in advance...
cd
Silver 99 F150 XLT 4.6l 4x2 Sport Extended Cab with Flare Sides...
Mods: K&N Air Filter, Tinted Side Windows, Flowmaster 40 Series Catback System, Reese Class 3, Airbox Mod's, Fiberglass Tonneau Cover, B&M Tranny Cooler, Tranny Temp Gauge, Water Temp Gauge, Autometer A-Arm 2 Gauge Pod Kit, Auburn Limited Slip Differential, Ford Bug Deflector, Alpine Deck, 6 Disk Changer & Subwoofer Processor, Zapco AG750 Amp (times 2), Zapco AG360 Amp, JL 10W3 (times 4), JL Audio VR Series 5.25" Component Speakers (times 4), JL Audio VR Series Tweets (times 2), & 1 Farad Cap (times 2)
Coming soon: Spray-On Bed Liner, B&M Electronic Shift Improver, Headers(?)
Coming this Spring: Kenne Bell Supercharger, BellTech 2"/4" Drop Kit, New Wheels & Rubber
cd
Corey, I purchased an electric gauge from Banks. It has the 1.5" copper probe and screws into the transmisson where you simply have to screw out the "sender plug". I had to go to the dealer to see a picture of exactly where this plug was and went home and inserted it where Ford indicated and works great! Put some teflon tape around the sender fitting before you screw it in and you shouldn't have any leaks.
I opted for an electric gauge - I know some do prefer mechanical.
Good luck!
1999 F250SD, XLT, 4x2, SC, V10, 4.30, LT235x85x16R, Longbed, Ford rain gutters, Banks Trans Command, Banks tranny temp guage with Auto Meter single guage pod. Reese 15K fifth wheel hitch
Good luck!
F250NUT
Save us all the trip to the dealer. Where on the transmission is the plug?
Thanks in advance.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
Thanks in advance.
Look at this picture and you can see the test ports for the pressures and all. They are the plugs I think F250Nut is talking about. The arrows depict where the fluid return line is for the cooler. AODE is 4R70W also.
http://www.mn12performance.com/mn12-...fo/trans-tech/
This has some good info, but not all is perfect.
birdman
[This message has been edited by birdman (edited 01-11-2000).]
Thanks Birdman.
I've got the 4R100, but it appears to be in the same location as this (drivers side).
see ya'
see ya'
Which one of these two plugs in the picture did you remove to use for the Temp sensor? i.e. Which one is the "sender" plug? Is the banks unit exactly the same size as the plug hole and therefore ordered vehicle specific?
[This message has been edited by cphilip (edited 01-11-2000).]
I think I was unclear. The two locations with the arrows are already in use on the 4R70W for the cooler lines, tubes are attached. The picture is used to show that early AOD trannys had reversed flow.
The small black plugs to the left and lower down are 1/8"-27 npt pipe fittings for testing line pressures. Seems they would be the place to put a temp sender. You would need to use a bushing to go to the pipe fitting size supplied by the sender.
Sorry if I was unclear.
birdman
birdman
I see what you mean but it would seem difficult to go into a 1/8 inch hole with a 1/2 inch fitting of the banks unit or Corey's 1/3 inch probe on his Autometer one. I am asssuming the Banks sender might even be too big to fit into the hole even if you adapted upward to 1/2 inch? Corey's sure is. Does anyone know if there is a unit built to this 1/8-27 size at the sender to take advantage of these existing holes on the 4R70W? Man, that would be too sweet! Sounds like the 4R100 was easier to do huh?
There are standard pipe adapters for this application, brass ones from Home Depot or others will work. You may need to put an elbow on though to get the clearance.
Maybe an 1/8"MPT to 1/8"FPT 90° elbow and a 1/8"-X/X" adapter. Use Teflon tape on the threads but start it about 2 threads in so anything that might shed won't end up in the oil.
Remember to not overtighten since aluminum is soft.
birdman
birdman
Indeed, the install on the 4R100 was simple and quick. Before I did anything, I called he boys at: http://www.galebanks.com/GBhome.html
1-800-GET-POWER and spoke several times before I got things straight - but after that, it was pretty simple.
Is the E4OD trans the same? I've been thinking of adding one myself.
'97 F-250 L/D Lariat S/C, 4x4, 5.4, E4OD automatic, 3.73 gears, 4 wh. ABS and 4 wh. disk brakes, gray leather interior,keyless entry w/alarm, outside: white w/gray rocker section, sliding rear window (and it leaks too), tow package. Mods- Ford running boards, Ford ventsahdes, Color-matched bug deflector, AVS tail light covers, Tuff Liner bed liner, unknown brand of cat-back exhaust system (previous owner installed).
Iggy, the E4OD is not the same, but similiar enough. My father has a 1994 F250 460 E4OD, and installed the gauge himself. His E4OD has the plug in the same general location as the 4R70W / 4R100. I'd suggest if you don't see yours by visual inspection first, then go to your dealer and have them show you a pic of the location. Mine was on the drivers side and once I knew that, I found the plug and the installation job was sweet and simple. Good luck!
1999 F250SD, XLT, 4x2, SC, V10, 4.30, LT235x85x16R, Longbed, mud flaps,Trailer tow Pkg, Class IV hitch, Camper special, sliding rear window, rear privacy glass, Ford rain gutters, Lund wind screen, Banks Trans Command, Banks tranny temp guage with Auto Meter single guage pod. Reese 15K fifth wheel hitch
