Reverse gear
Old Jan 5, 2000 | 02:30 PM
Dnmeistr's Avatar
Question Reverse gear
I love my truck it is a 97 F150 4x4 that I bought used w/52K miles and haven't had a lick of problems with it other than the dealer put fouled plugs in it at the 60K mile checkup, but that is another story I do not want to get into. My only complaint on the truck is that reverse gear on the 5 speed seems to be higher than 1st so that when I backup a mild to medium incline I either smoke the clutch or have to ride it to keep from stalling. So most times I have to put the truck into 4 low to backup a hill. I do not have this problem in 1st gear. Anyone else have this problem, or is it just my the clutch.
Dnmeistr
Old Jan 5, 2000 | 03:46 PM
jgorka's Avatar
Thumbs up
Reverse gears often get the least attention during the design phase of a transmission. Their ratio is usually limited by available realestate in the gearbox -- and sometimes sacrifice noise for strength (spur) -- and smaller is 'taller' in your case.
You've already figured out the best work-around -- the extra reduction provided by the transfer case.
Old Jan 5, 2000 | 11:09 PM
mpineda's Avatar
Post
I too have the same problem. I thought it was just my truck but it still does it after a new clutch and rebuilt transmission. I guess you just have to take the good with the bad.
