Transmission Fluid
Old Dec 9, 1999 | 08:56 PM
Tom S's Avatar
Question Transmission Fluid
I have a 1997 Ford F150 with the 4.6L engine, 4 wheel drive, and the 4R70W automatic transmission. My owners guide recommends mercon automatic transmission fluid. The Haynes repair manual states to use Mercon V. Which is correct and what is the difference?
Old Dec 12, 1999 | 03:22 PM
6869's Avatar
Post
Hi Tom S!
I am still not sure what the difference between the two is, but see my post "Difference between Mercon/Dextron III and Mercon V" under this heading. I belive that only late 98 and up have Mercon V and that your truck (97) still uses Mercon/DextronIII.
Chris Raith
1999 XL S/C 4x4, 4.6w, auto, LS 3.55
XL Appearance Group (Polished alloys, 40/60 bench, colour-keyed bodyside mouldings)
XL Value Group (Air, AM/FM Cassette)
Tilt & Cruise
Old Dec 12, 1999 | 03:51 PM
Dunbarton's Avatar
Post
Your transmission refill stick handle should be labeled with what to use. Trust your original owner's manual.
Mercon IV is synthetic while Mercon III is not. Don't mix them for your transmission.
Dunbarton "The Middle Aged Kid" '99 XLT SC SB 4x2 4.6 auto 3.55 ls The occasional Z-71 Eater! Wedgewood & Denim, SuperChipped, Airaid FIPK, Rhino Liner, Mobil 1. Man, I got it all! (New Jersey)
[This message has been edited by Dunbarton (edited 12-12-1999).]
Old Dec 14, 1999 | 12:58 AM
franks&beans
Guest
Posts: n/a
Post
The top of your tranny dip stick cap should tell you what brand to use.
Happy Holidays,
F&B's
98 F-150,4.2L auto, 4.10 gears w/ LS, Tow Pkg. BFG AT 265/75/16, K&N air filter, Dynomax muffler, Edlelbrock shocks, Hellwig sway bar
[This message has been edited by franks&beans (edited 12-14-1999).]
