Has anyone ever seen this???
Old Nov 18, 1999 | 07:56 PM
MikeS's Avatar
Question Has anyone ever seen this???
Hi,
A friend of mine has a '97 F150 with the 4.6.
The light on the shifter that comes on when you disengage the overdrive (OFF) is flashing on and off...??? He says it only happens after the truck has warmed up... Does anyone have any ideas what causes this??? He checked the fluid and it's ok... He also says that while the light is flashing the transmission clunks as it downshifts...
Mike
99 Lariat S/C 5.4 4x4 Amazon Green/Harvest Gold 3.55/LS K&N Filter Mobil 1
Oshkosh, WI.
[This message has been edited by MikeS (edited 11-18-1999).]
Old Nov 18, 1999 | 08:18 PM
Pastmaster's Avatar
Post
Im not sure about the newer F-150's but mine continueously did that on my 93, and I took it in, and they found that the lights and module inside the shifter was bad. Got a new one for 13 bucks
Old Nov 18, 1999 | 09:47 PM
j.b.'s Avatar
Post
MikeS: Have your friend go to a Ford dealer and have the code scanner read what the problem with his transmission is. This is how the tranny "tells" you that some malfunction has set the light off. The O/D Off light becomes the tranny MIL (Malfunction Indicator Light) when it pulses. A code has been sent to the computer, get it read soon to prevent damage. j.b.
99 SC Sport, Silver color everywhere, 4.2 auto,3.55 rear gear, split bench, stock AM/FM @ 2 cheesy speakers w/Ford brand bedliner. Keep'n stock from the factory because we love it for what it is...One fine ride!
Old Nov 18, 1999 | 10:13 PM
MikeS's Avatar
Post
Thanks guys,
That's what I told him to do too. I guess he wanted to know what it was so he could tell if the dealer was trying to take him for a ride...He asked me, I didn't know, So I told him I'd check here for him...
Mike
3.55/LS
K&N Filter
Mobil 1
Oshkosh, WI.
Old Nov 18, 1999 | 10:44 PM
94fan's Avatar
Post
Had the same problem with my 97. Ended up being water getting in the transfer case causing the speedometer drive gear to swell. Eventually the speedo will probably quit. Ford has a redesigned breather and speedo gear. Also there is a TSB on this. I will find the number and post it on 11/19. Ask your friend if his windshield wipers work correctly,believe it or not this will affect the wipers.
Old Nov 18, 1999 | 10:54 PM
MikeS's Avatar
Post
94Fan,
How did you figure out what the problem was??? Did the computer "code" it out or did the speedo quit?? The wipers???? That's wild!!! What the h*ll would the wipers have to do with it???
Thanks for your help
Mike
3.55/LS
K&N Filter
Mobil 1
Oshkosh, WI.
Old Nov 18, 1999 | 11:14 PM
94fan's Avatar
Post
Mike S, I had a code for vehicle speed sensor. Local ford dealer replaced the drive gear but did not replace the breather. 3 months later o/d light started flashing again. I have a friend in another Ford dealer and he made copies of all TSBS that related to this problem. TSB 97-11-19 is the one that addresses this problem. This may be a different problem than your friends,hope this helps. As for the wipers,the transfer case mode switch must get water in it causing it to short,affecting intermittent wipers and 4x4 range light to light dimly. If you cannot get a copy of this TSB let me know and I will get it to you.
Old Nov 19, 1999 | 11:28 AM
T Ellenberger's Avatar
Post
My friends 97 F-250LD flashed like that and it was the speed sensor on the transmission, not the speedo gear.
He replaced it himself for less that $40.
The dealer told him what the problem was just from the description he gave.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, 4.6, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
Old Nov 24, 1999 | 09:21 PM
MikeS's Avatar
Post
94fan,
He had the computer checked today...It sounds like the same problem... He said it also coded out a problem with the wipers... If you could send me a copy of that TSB it would help like hell...
Mike
dom@vbe.com
3.55/LS
K&N Filter
Mobil 1
Oshkosh, WI.
[This message has been edited by MikeS (edited 11-24-1999).]
Old Nov 26, 1999 | 04:26 PM
94fan's Avatar
Post
MikeS-I sent you an e-mail at address listed. Just in case you dont receive it,e-mail me your street adress or a fax number and I will get the tsb to you.
edeakins@eurekanet.com
